Help please. On my "73 GTV the dashlights, taillights, brakelights and one headlight went out simultaneously. Turn signals still work.
I have a wiring diagram generously supplied on this forum but components are not all identifiable.do you have a wiring diagram?
Thanks everyone! Turns out it was corrosion in the 48 year old fusebox. I sprayed it with electronics cleaner and voila! everything came back on at the same time, brighter than before.Headlights each have a separate fuse.
But they all have a common feed on the back of the fuse box.
Check your grounds, or the switch.
