· Premium Member
There are some numbers missing. Some numbers are cast in the core, some are stamped after it's ground. Probably there is a 5 after the first 1 and 0? And maybe a couple more farther along? They are often above or below the line of cast numbers.
Moving this to the regular engine forum.
· Premium Member
Shankle lists 101210320000 - 1600 Veloce; 9.5mm lift, performance rank 7
and
101000320000 - 1300 Normale; 8.6mm lift, performance rank 1
Those are the closest numbers in the catalog to the one that you posted.
· Richard Jemison
Cam
It is the Shankle.
No, it`s only on the Shankle list of Alfa cams.
It is the stock 1600 Veloce cam from the 101 series cars. It received a "7" rating based on duration. You will find them weak at low and mid range RPMs.
That can be improved by changing the cams lobe centers to 104/104.
