Does any one has the measurements of the clutch assembly tool?
I have the idea of making il myself with lathe.
Thank you
Inviato dal mio Nexus 5 utilizzando Tapatalk
Just measure the input shaft on the front of the gearbox
it doesn't require teeth for the clutch , i need the minimum diameter, right?
yes or you can measure the inside of the clutch where the spigot shaft goes in . I've used a piece of dowel turned down on a wood lathe an just test fit not tight not loose
p. s. don't forget to allow for the spigot bearing so it lines up
