My Berlina has been acting funny lately. It's been hard to get it into gear without completely grinding the hell out of them. It's pretty embarassing when you are trying to sell it and the person looking/driving it can't shift the gears. Anyhoo...this is how you fix it (forgive me if you all know how to do this):
If you open the hood and looks for the brake master cylinder, mounted on the left of it is the clutch fluid resevoir and clutch cylinder thingy(?). If you look toward the firewall you will see a locknut with a pushrod that goes to a piston the pushes the fluid that actuates the clutch disengagement lever.
To adjust the engagement/disengagement loosen the locknut and rotate the pushrod (it's threaded) in the appropriate direction. When done lock the locknut down again and bingo! Your clutch will engage/disengage correctly again.
Now keep in mind that this whole system, at least on my Berlina, is a self adjusting mechanism so this process maybe just treating a symptom and not the actual cause of the problem.
I'm just learning all this stuff so when I am able to fix even the simplest stupid thing I'm excited. I'm a dork.
Happy Merry Easter and all that stuff!
