I would have used "long restoration" but that title is already taken and hopefully will be more true for that work than for mine.
I earlier posted the rotisserie pics. The car is now up having its paint, rust, and bondo removed via soda blasting and other media. I go up shortly to look at it, and possibly become disheartened at the work ahead. Months of disassembly, sorting, and parts acquisition. I remain convinced that the shell is salvageable, but fully expect some teeth gritting when I see the details of the previous rocker repair.
I intend to build up both original 102 and FNM 2300 engines for use in the car. The 102 is a big sluggish at sea level, and at 5,000 msl, to 7,000 msl (to get to Lake Tahoe), I'm not expecting much with the original engine. Different than Jay's oft-noted experience, I've had perfectly good results tuning and operating the Solex PHH44's, but the modern manifold on the FNM/Rio engine is set up for either the DDH's or Weber DCOE/OM carbs. Hopefully I can make all that work, and pick up some more grunt in the front.
The FNM engine is coming apart now. I can't tell if it is low time, or just a fancy silver re-spray to make it look good. The upper timing chain was removed by someone along the way, and there is zero compression, so I'm half expecting some rather interesting valve-heads when I get it apart. It turns very easy, so at least no major internal rust.
There are pictures below to show some of the differences between the 102/FNM. The clutch is a diaphragm type, and has a different bolt pattern the the unit on the 102/106. This should pose an interesting challenge, as well as finding out if the Alfa trans mates up, and fits the pilot bushing and clutch disk spline.
The distributor and starter are both Bosch, but made in Brasil back in a time when they were intensely protective of their economy. Still, one must wonder if there is a Bosch warehouse somewhere with a couple of dusty shelves....
Off to see the rapidly-becoming-naked shell.
Don
Don
