1 - 9 of 9 Posts
From a 101 Giulia spider veloce correct intake and valve cover, maybe used on other alfas. No breather and the center drop for the veloce rubber tube air hose, note the intake photo no extra nipple, these are rarer.then the 101 1300 veloce .
package price for the two 475.00 usd ,plus shipping
Akron,Ohio
OBH
Inlet manifold
would be interested in the manifold, do you sell alone.
best regards
Uli
101 veloce valve covere
Have a buyer for the 101 1600 veloce valve cover, waiting on a check. Intake is available. Keep in mind this intake is not an easy item to find, not many 1600 cc 101 Veloces made. Also, I believe used on the Super TIs.
owen
I have manifold like this--which I also think is a Veloce manifold. Mine is slightly different in that the boss you show is drilled for a heater hose ,but the the rear of the big fitting at the end of the manifold is not drilled. The intake bore is straight from carb to head. I looked at a 1300 manifold and this is tapered,with a smaller diameter at the cyl. head end of the bore. Rick
1 - 9 of 9 Posts
