1 - 2 of 2 Posts
3 - core 1750 CC blocks used on 1969 and 1971 US Alfas -
Great shape - excellent decks and liner spigot surfaces. NO CORROSION on machined surfaces or at base of block near head stud locations. Head studs and threads in excellent condition. Assume all should be line bored before a fresh rebuild. ComeS with original main bearing caps.
Keep those GTV's original for top $ or at least have the right block saved under the work bench...
Ships from Rochester NY - 14543 Zip
Boxed at ~ 50 pounds, 20 x 20 x 14"
Example > Shipping to Los Angeles, California ~ $70
Asking $350 / BO
Other 1750 parts -
JE High compression Piston and liner set with NEW Rings and pins - 4 race weekends $375
Good crank will be advertised shortly - Still at shop getting Micro Polished - Oil galleys Drilled / Tapped / Plugged
Pans and other parts may be available -
No heads -
Pics Typical of all blocks
Chris D
585 330 5456
[email protected]
1656843
1656844
1656845
1656846
1656847
00551 00554Block with main caps1969 US GTV / Spider / BerlinaNumber two Main Scuffed - needs Line Bore
00551 1898Block with main caps1969 US GTV / Spider / BerlinaPreviously Lined Bored - repaired properly - Steel Sleeve in the top of #2
00551 06934Block with main caps1971 US GTV / Spider / BerlinaScuffing on number two Main
Transport Vehicle Automotive wheel system Soil Asphalt
1 - 2 of 2 Posts
