Alfa 164 TSB 00.91.01
Alfa Tech Bulletin from 1991. Interesting to read all that has happened since this thing was published: Alfa 164 TSB 00.91.01
PIPE DREAMING by Time Standard Xspurts!
Notice that the time allowed is 3.7 hours on a 164 12v engine. Just checked Alfa Flat Rate Manual for 12v and 24v and same 3.70 hours is listed time standard for 12v just as bulletin states and 24v listed as 4.50 hours. Operation Code 0332 100.
Do you think anybody can do it correctly in that time? I doubt anybody can do it in thoses times and have confidence timing and tension is correct especially on 24v.
They allow for water pump change which has to assume you are removing timing belt to get to it 4.75 hours on 12v and 5.70 on 24v again a pipe dream especially on 24v. Operation code 0710 100
