Thanks a lot for your answer . or try to find the 40 dcoe 32 . the pair i have should have a rebuild anyway.Yes. The 1750 engines were delivered world wide with Weber 40 DCOE 32 carbs except the so called fuel injected USA 1750s which were not 548. The 548 engine is a good engine.
Your Webers can likely be easily rejetted and sized to match the stock carbs.
Welcome to the Alfa BB.
Ken
thanks alot Richard for your helpfull answer , this is a super forum i thinkYou dont need DCOE 32s, Any Italian made Weber DCOE (2/4/9/28/18/27/24 14/32 can be jetted and fitted with the correct Venturis to run well.
The setup for 32s (AND others) have been posted on the BB. But the 32`s setup is for the 10548-01 cams that engine came with. .
