Front sway bar bushing lesson learned - Alfa Romeo Bulletin Board & Forums
 2Likes
  • 1 Post By dmericas
  • 1 Post By slowcreek
post #1 of 5 (permalink) Old 07-11-2019, 04:06 PM Thread Starter
dmericas's Avatar
For the good of the community I want to share some knowledge I gained when replacing the front sway bar link bushings on my 1974 2000 GTV. I ordered a set from a large US Alfa parts supplier that appeared to be for my car. The bushings I received were 26mm in diameter, while the old bushings on my drop links were 30mm diameter.
I called the supplier and was told the listing description that crossed to my car showed 26mm (it does), 30mm are not available, and it was suggested the links were from another car (no reason to believe this) so it was my responsibility. They offered to refund the parts price but not shipping in either direction.
I checked with my British supplier (Classic Alfa) and learned there were three different diameters used on GTVs (26, 30 and 33) depending on year, and 30mm is correct for a 74. I got a set of 30mm from them and they fit perfectly.
Two lessons learned: 1) read part descriptions very carefully, even if the website lists the part for your car; and 2) Alfa parts specialists donít always have staff who truly know the intricacies of these cars.
alfaloco likes this.
Dean
1974 2000 GTV / 1976 Giulia Nuova Super 2.0 / 1965 TR4
dmericas is offline
post #2 of 5 (permalink) Old 07-11-2019, 04:31 PM
alfaloco's Avatar
So Dean, what you are talking about are the end link bushings, not the bushings at the chassis, correct? And it sounds like there are three different OD sizes for those end links, then. Never having owned a 105 GTV, I was not aware of that detail.
A very helpful post, sir! Thanks.
alfaloco
Lexington, KY USA
alfaloco is offline
post #3 of 5 (permalink) Old 07-11-2019, 07:00 PM
slowcreek's Avatar
I've gotten all the needed poly bushings for my 78 Spider and my 78 Sport Sedan right here in the USA.
Performatek has all that you need. They're in Massachusetts or New Hampshire. Andy knows his stuff.
alfaparticle likes this.
It's Giuseppe's giubos, not Guido's guibos, on my 78 Alfas
slowcreek is offline
post #4 of 5 (permalink) Old 07-11-2019, 09:09 PM Thread Starter
dmericas's Avatar
Exactly.
Happy to share the info since it was such a mystery figuring it out.
Dean
dmericas is offline
post #5 of 5 (permalink) Old 07-11-2019, 09:18 PM
slowcreek's Avatar
Polyurethane Bushings
