Steering Idler - repro with roller bearings - Alfa Romeo Bulletin Board & Forums
post #1 of 4 (permalink) Old 05-23-2019, 06:10 AM Thread Starter
r-mm's Avatar
I'm ordering a few parts to address some things I neglected during my rebuilt. Can't say I paid the idler any attention whatsoever. Debating a rebuild (
But also see a roller bearing alternate on offer which seems to take up less space. Any intel here? Frankly can not tell what other problems may lurk in an old idler but if they mimic those latent in rebuilding a burman... I'm tempted by the repro.
https://classicalfa.com/su080-steeri...er-repair-kit/
https://classicalfa.com/su079-1-lhd-...ller-bearings/
'73 GTV bare metal project... nearing 'car' status
E30 Daily - '65 912 project... no longer in waiting
r-mm is offline
post #2 of 4 (permalink) Old 05-23-2019, 07:32 AM Thread Starter
r-mm's Avatar
CA clarifies below. Is the pin an item that is commonly pitted or not practical to reuse?
The repair kit will definitely need welding if you use the new pin, some people reuse the old pin and just use the new bushes.
The roller bearing kit doesn’t come with a new arm so you need to reuse the old pin and arm.
r-mm is offline
post #3 of 4 (permalink) Old 05-23-2019, 07:39 AM
Member
otteud96's Avatar
How is your arm, typically if your bushings are worn out so is the shaft. If your arm is ok and you can choose euther option . Good luck
otteud96 is offline
post #4 of 4 (permalink) Old 05-23-2019, 07:47 AM
Gubi's Avatar
The shaft rides in plain bushings. When they wear (very common) you get play in the steering.
The two options are to either replace the bushings in your current idler, or replace the whole idler with one with roller bearings. The shaft will usually clean up okay but if it's really pitted it'll need replacement, which requires a good welder.
Some more info here: https://www.alfabb.com/bb/forums/spi...-bushings.html
1974 GTV
1991 Spider
Former: 1987 Milano Gold
Gubi is online now
Similar Threads
For Sale: steering box worm and roller 2000 spider and 1900CSS franco-veloce Alfa Romeo Parts For Sale & Wanted 0 05-01-2019 03:53 PM
Replacing a Burman Shaft-Type Steering Box Seal In-Situ Roadtrip Spider - 105 & 115 Series (1966-1994) 64 03-25-2019 06:17 PM
source for bearings on later 101 ZF steering box box pescara Giulietta & Giulia (1954-65) 7 04-06-2018 04:40 AM
Wanted: Giulietta Sprint steering idler box sagebrushbob Alfa Romeo Parts For Sale & Wanted 1 05-30-2013 08:05 PM
Steering Effort Question JBWesterwick Spider - 105 & 115 Series (1966-1994) 8 09-03-2010 08:36 PM
