Remove rear sway bar? - Alfa Romeo Bulletin Board & Forums
 1Likes
  • 1 Post By Gubi
post #1 of 8 (permalink) Old 05-08-2019, 07:45 AM Thread Starter
duemila's Avatar
I would like to have your pro's and con's on my idea to remove the rear sway bar on my Berlina 2000.
Current Situation:
I have shorter/harder springs (Eibach), new dampers (Bilstein front, Spax rear) and a new bigger sway bar in front, and also renewed all bushings. Compared to the old suspension (+40 years) it corners way better and faster. But: it somehow feels like a bit too much grip in the rear. It is not exactly understeering, but like a slot car taking a narrower circle... sorry for that weird description. For a track car that might be perfect, but I would prefer a little (!!!) oversteer.
Then I came across Alfaholics' recommendation to remove the rear sway bar on cars when using their handling kit - might that be the solution in my case?
Any experiences appreciated
Joerg
Oo-\/-oO
duemila is offline
post #2 of 8 (permalink) Old 05-08-2019, 07:55 AM
VabeneGTV's Avatar
Worth a try, sounds like a similar setup to Alfaholics and Classic Alfa’s fast road offerings.
Cars ruined my life! 😱
VabeneGTV is online now
post #3 of 8 (permalink) Old 05-08-2019, 08:40 AM
Gubi's Avatar
You stiffen the end of the car where you want less grip. If you want more oversteer generally you'd want a bigger rear bar, not smaller.
Image from https://centerlinealfa.com/tech_suspension_adjust
horsewidower likes this.
1974 GTV
1991 Spider
Former: 1987 Milano Gold
Gubi is offline
post #4 of 8 (permalink) Old 05-08-2019, 09:22 AM
105 Alfa's are prone to oversteer, particularly when you try to put down power before the car has straightened out. That is why many people who drive fast remove the rear bar. I have tried several combinations and my favorite for fast road driving is the stock bar on the front and no bar on the rear with Shankle Super sport springs which are similar to the ones sold by Alfaholics. You generally need less bar with stiffer springs.
2011 Jaguar XKR
alfaparticle is offline
post #5 of 8 (permalink) Old 05-08-2019, 10:21 AM Thread Starter
duemila's Avatar
Wow, you're quick
OK, your explanations and the overview sound understandable, so maybe the original bar in the current setup is what I would like to feel in corners.
Thanks!
Oo-\/-oO
duemila is offline
post #6 of 8 (permalink) Old 05-08-2019, 02:16 PM
You can just unbolt one end and tie it up to try it out. If you like it better then you can remove the whole thing.
Sent from my ONEPLUS A3000 using Tapatalk
Ian Lomax - Current: 1973 Berlina, 1987 Milano Platinum "racecar"
Past: 71, 74 Spiders, 2x 74 Berlina, 74 GTV, 76 Alfetta GT, 88 Milano 3.0, 164LS
archeologist is offline
post #7 of 8 (permalink) Old 05-09-2019, 06:25 AM
GTA R's Avatar
I'm on my third fast road Alfa (2 coupe's and currently a saloon), and have fitted the Classic Alfa Harvey Bailey handling kit to all of them.
(Lowered, stiffened springs front & rear, + 29mm front anti-roll bar.) Each time fitted with Koni Reds, half hard front & full soft rear
I've removed the rear bar in each case, and find it perfect.
On the current Ti Super Rep, I have adjustable top arms dialled in with one degree of negative camber and it really helps the turn-in.
GTA R
1963 Giulia Ti Super Rep
GTA R is offline
post #8 of 8 (permalink) Old 05-09-2019, 07:17 AM Thread Starter
duemila's Avatar
I'm not saying it doesn't ride well, I just prefer to have a bit more lively rear axle. Probably I'll give a bit more negative camber in front and then it's perfect. Hard to describe anyway...
Thanks for your input
Oo-\/-oO
duemila is offline
Similar Threads
May the circle remain unbroken - 10204 01488 DPeterson3 1900, 2000 & 2600 (1950-1968) 1041 08-21-2019 10:36 AM
102 Sway bar installation DPeterson3 1900, 2000 & 2600 (1950-1968) 7 01-05-2019 05:01 PM
help with 1969 rear bushing size rear sway bar alfaman Suspension, Steering, Brakes, Wheels & Tires 7 11-15-2016 09:09 PM
Opinions - heavier rear sway bar 71 Spider? Lokki Spider - 105 & 115 Series (1966-1994) 17 08-15-2016 05:46 PM
Rear sway bar endel Suspension, Steering, Brakes, Wheels & Tires 2 03-07-2006 08:30 AM
