Lower a arm wear - Alfa Romeo Bulletin Board & Forums
 1Likes
  • 1 Post By andylarry
post #1 of 4 (permalink) Old 05-05-2019, 07:46 AM Thread Starter
Alfasergio's Avatar
Lower a arm wear
I am currently in the process of replacing the lower a arm solid bushings. Upon splitting the arm I see that the bearing may have run dry at one point. The picture is of the bottom of the arms where the bearing is pressed on.
Can I sand this smooth, or should I find a replacement?
The last image is of the only side without wear.
[SIGPIC][/SIGPIC]1974 Alfa Romeo Spider
Alfasergio is offline
post #2 of 4 (permalink) Old 05-05-2019, 08:18 AM
Richard Jemison
Alfar7's Avatar
wear
You can polish off the raised wear ridges, but don`t reduce the diameter of the pintle.
As well you should coat the pintles with high temp waterproof axle grease.
In the `60s the reccomended solution of "groaning/ and squeaking"
suspension bushings was to drill through the bushing assembly (installed) and use grease fillings to lubricate the bushings. My Duetto had that done in 1968 and still rides on the same bushings with shots of grease yearly.
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is offline
post #3 of 4 (permalink) Old 05-05-2019, 08:21 AM
I would say that the retaining nut came loose and the inner sleeve of the bushing was rotating on the shaft. The normal operation of that component would be that the inner sleeve is held tight on the shaft, the outer portion of the bushing is held tight on the lower A-Arm, and the reciprocating motion occurs inside the bushing.
PSk likes this.
ALFA ANDY
andylarry is offline
post #4 of 4 (permalink) Old 05-05-2019, 09:19 AM Thread Starter
Alfasergio's Avatar
What would be a suitable media to polish the pintle with?
Similar Threads
Replacing a Burman Shaft-Type Steering Box Seal In-Situ Roadtrip Spider - 105 & 115 Series (1966-1994) 64 03-25-2019 06:17 PM
lower control arm bushings Mark_toro Milano/75 (1985-1993) 9 10-23-2017 10:26 AM
Wanted: 750 Giulietta lower A arm pins DaveB Alfa Romeo Parts For Sale & Wanted 2 05-31-2017 02:34 AM
Lower control arm bushings on 105 Dave De Rosier Suspension, Steering, Brakes, Wheels & Tires 3 12-30-2014 10:04 AM
Help! Ride-Height & Lower Control Arm Issues! junglejustice Milano/75 (1985-1993) 8 11-01-2003 02:36 PM
