Wheel lug question - Alfa Romeo Bulletin Board & Forums
post #1 of 6 (permalink) Old 09-25-2018, 06:04 PM Thread Starter
Wheel lug question
So my Spider came with a set of wheels and spacers. Unfortunately they cut the original studs. The spacers don't bother me, but I acquired a set of original 14" FPS 5 star wheels which I liked better. The problem is there is not enough stud that I feel comfortable to drive around with. So I need to re stud the spacers and get a proper set of lug nuts.
Anyone have the correct size and if possible a picture of the lug nuts to use?
triz is offline
post #2 of 6 (permalink) Old 09-26-2018, 12:16 AM
Tom Frasca's Avatar
These may work give them a call, check the profile, taper, and depth ,
http://www.vickauto.com/newstore/ind...oducts_id=1538
or
https://www.alfaholics.com/race-part...uts-manufactu/
Tom Frasca is offline
post #3 of 6 (permalink) Old 09-26-2018, 04:48 AM Thread Starter
Any idea on the studs?
triz is offline
post #4 of 6 (permalink) Old 09-26-2018, 05:30 AM
Tom Frasca's Avatar
Both vendors should carry studs.both are available to speak with Alfaholics guys are very knowledgeable,
post #5 of 6 (permalink) Old 09-26-2018, 09:19 AM
Charlie DiMarco's Avatar
How many turns of engagement are you getting with the nuts you have ? Industry standard is 6 turns.
Use ET lug nuts to gain some tread engagement. You will have to drill your wheel seat with a 6mm or 15/64 bit to make clearance fort the extented portion of the shank.
Charlie
Serpent Autosport
Charlie DiMarco is offline
post #6 of 6 (permalink) Old 10-30-2018, 12:34 PM Thread Starter
I was only getting 5 or 6 in the back. I bought new studs from Classic Alfa and just did the rears over the weekend with new black lugs from RockAuto. Feel much better and safer now. I finished cutting the old ones off and unhooked the top e brake and was able to slide the new ones into the e-brake hole and tap the new ones in place.
triz is offline
