Slack steering - Alfa Romeo Bulletin Board & Forums
post #1 of 3 (permalink) Old 09-13-2018, 10:10 PM Thread Starter
Slack steering
Hi there, just this eve the steering wheel on my 83 spider veloce started to feel quite sloppy / light, esp when stationary. Maybe an inch or two of give which didn't really occur before. No real problems steering, just the feel is different. Likely issue tie rods? Thanks!
henrycarroll is offline
post #2 of 3 (permalink) Old 09-24-2018, 05:28 PM
I would start by checking your steering box. I had one crack and it exhibited the same symptoms. If it checks our then yes I would check tie rods next.
Sent from my ONEPLUS A3000 using Tapatalk
Ian Lomax - Current: 1973 Berlina, 1987 Milano Platinum "racecar"
Past: 71, 74 Spiders, 2x 74 Berlina, 74 GTV, 76 Alfetta GT, 88 Milano 3.0, 164LS
archeologist is offline
post #3 of 3 (permalink) Old 11-01-2018, 08:22 AM
Andrew's Avatar
If it was a sudden change I'd suspect tie rod ends, yes. Get the front end up, pry and test them all, see if there's slop. Could also be worn idler box.
There is adjustment to the steering box, easy if a ZF, not as easy if a Burman. And make sure there's oil in it.
Andrew
Andrew is offline
