Cracked Steering column support GTV - Alfa Romeo Bulletin Board & Forums
post #1 of 1 (permalink) Old 09-13-2018, 04:36 PM Thread Starter
r-mm's Avatar
Has anybody seen this before? It is likely my fault as I could not get the steering column tight in the steering column support and probably over stressed the bolt that pinches them together. Is it correct that this both alone is what restricts fore aft movement of the steering column in its support?
Obviously the big nut at the column to steering box slip joint also restricts maximum aft travel.
Size:  194.3 KBName:  IMG_5429.JPG
Size:  203.6 KBName:  IMG_5430.JPG
'73 GTV bare metal project... nearing 'car' status
E30 Daily - '65 912 project... no longer in waiting
r-mm is offline
