ATE booster - Alfa Romeo Bulletin Board & Forums
post #1 of 4 (permalink) Old 08-20-2018, 09:24 PM Thread Starter
goats's Avatar
ATE booster
Hi All
My 71 spider had an episode of 'hard brake pedal/ loss of efficient braking'. It was a two-off event, and I have not been able to replicate it other than to remove the vacuum line to the booster. Seems unlikely that I lost vacuum for those two events, car was running great and the hose is new, master is new, booster is what came with the car but seems to be working (mostly!)
So I pulled a ATE booster out of the cabinet to see if I could conjure up a scenario where this might occur, and I THINK I might have found one.
The booster has a metal rod that is firmly connected, and runs through a plastic cylinder (about 2 inches diameter) that sits on the pedal side. In order for the booster piston to travel in and out, this larger diameter rod passes through a seal on the pedal side, moves in and out, and the cylinder is actually what attaches to the diaphragm in the booster body.
If that large diameter cylinder got hung up (off angle and / or binding) we would have a stiff pedal. Seems logical and reasonable that the metal rod (concentric to the larger cylinder) needs to be free to move in and out of that seal,
The plastic cylinder is under the accordion boot on the pedal side. I wonder, should the OD of that cylinder be lubricated to make it easier to pass thru the seal, and to reduce any off-angle loading? If yes, what lubricant to use ? Seems to make sense again since the cylinder is under the accordion bellows and thus protected.
What say ye? Silicon based oil ? Teflon grease? I do think this is likely my issue on the spider as there is nothing else that moves except this rod/cylinder.
goats is online now
post #2 of 4 (permalink) Old 08-23-2018, 02:16 PM
Del
Maybe ask in the Spider section. Some don't peruse much of the BB I suspect.
Del
Seattle
1989 Milano, Shankle Sport
1991 164S, stock
1994 164LS (~Q)
1972 Morgan 27
previously owned since 1964:
Del is offline
post #3 of 4 (permalink) Old 08-25-2018, 07:55 PM
Member
Chief's Avatar
Hi there, you can use a good silicone grease or just use some Dot-4 brake fluid. Use it sparingly, a little goes a long way. By the way, don't dismiss the vacuum check valve in the intake manifold. It can corrode inside and the spring can brake from rust. good luck, Chief
James (Chief) Bridges
J & J Racing, LLC,
Chief is offline
post #4 of 4 (permalink) Old 09-09-2018, 10:02 AM
Andrew's Avatar
That sounds like the air valve on the atmospheric end. I had one on a rebuild booster, sat on my shelf a long time and got a bit cruddy. Worked OK while engine ran but wouldn't close and hold vacuum afterward. Sent it back to the rebuild shop, they cleaned and lubed, all good.
It does take some effort to move the actuation rod from the pedal shaft, through the booster, to the MC. But you should be able to do it by hand.
Andrew
Andrew is offline
