105: New control arms point slightly backwards - Alfa Romeo Bulletin Board & Forums
post #1 of 9 (permalink) Old 09-01-2016, 03:39 PM Thread Starter
AlessandroM's Avatar
Hey there
The title says it all, I installed new adjustable arms and they seem slightly pointing backwards after connecting it to the caster rods/arms. Which made me wonder and ask for advice here!
What I did:
- Install polybushings on the inner bush of the arms
- I tried to aim for the length of the original arms for later adjustment.
- The arm is not connected to the upright yet
Both arms point consistently backwards
So, am I just worried about something that is totally fine? How do yours look?
Grazie mille
Alessandro
Learning, learning..
AlessandroM is offline
post #2 of 9 (permalink) Old 09-01-2016, 03:48 PM
Push hard and live
DPeterson3's Avatar
Possible a PO dealt with shot caster arm bushings by lengthening the caster rods?
Don P
Carson City, NV
Past Alfas...
Current Alfas
Oops. Add to the "present" list, 10204 01488, 2000 Touring Roadster project
And past...
1946 Luscombe 8A
And present...
64 Mooney M20E ("Rambo". My faithful steed for over 40 years) Over 55 years old, and just returned from a trip to Argentina in him
Newest in the fleet
2010 Triumph Thunderbird
DPeterson3 is online now
post #3 of 9 (permalink) Old 09-01-2016, 03:53 PM Thread Starter
The Caster Bushing looked fine to me. I only changed the arms because I wanted adjustable ones. I also compared size and distances of bushing to bushing and they seemed all the same.
Can I assume then that the push-back is not normal? The arms still move freely btw.
post #4 of 9 (permalink) Old 09-01-2016, 04:53 PM
Push hard and live
DPeterson3's Avatar
Is the inner bushing centered in the pocket?
Ultimately, it'll be what the alignment rack that tells you that matters.
Have you compared the outer ends of a new and old rod to see if the caster bushing ring has the same distance and angle from the ball joint?
Don P
Carson City, NV
Past Alfas...
Current Alfas
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
post #5 of 9 (permalink) Old 09-01-2016, 10:29 PM Thread Starter
I will recheck the all the distances, to make sure. The inner bushing is centered and fits snuggly into the hole between the two plates.
I am also going to install the old arms temporarily to see whether the PO had the caster setup like that.
Thanks!
post #6 of 9 (permalink) Old 09-04-2016, 02:03 AM Thread Starter
So it seems quite a bit of people run caster like that. (e.g. http://www.alfabb.com/bb/forums/gt-1...ml#post6742201 ) I just do wonder what amount of caster i am running currently (lacking the tool to measure) could be and if its good for the bushing back there to spread it like that?
post #7 of 9 (permalink) Old 09-04-2016, 06:32 PM
Born Again Boarder
Anfanuts's Avatar
If worse came to worse, [SARC] you could always take it to an alignment shop and have it all checked (caster, camber and toe). New adjustable control arms can throw the camber off unless adjusted to the same length. Always advisable after a suspension rebuild. Specs in the OM.
PS: I had an Alfa with different length caster rod adjustments and upper arm positions because some PO hit a curb and pushed the whole right side back. That unequal adjustment was required to get that side correctly tracking.
Anfanuts is offline
post #8 of 9 (permalink) Old 09-04-2016, 11:05 PM Thread Starter
Hey @Anfanuts
I setup the controls arms just as the fixed ones, so i can start from where I was, which wasn't particularly bad. Each side is equally caster-y and thus i think it was intentional by the PO. Still I do wonder - what does this caster do to the life of steeringbox and bushings?
post #9 of 9 (permalink) Old 09-05-2016, 08:09 AM
a lot of people crank caster into the front end... sometimes for damage control, but mostly to increase front grip. more caster adds neg camber dynamically during turns -and then goes back to static camber when wheels straight ahead. will increase steering effort and give more "snap back" to straight ahead wheel position when come otu of turn. put together and then take for front end alignment. very worthwhile on any car that has not had it done in awhile.
barboncino105 is offline
