'69 GTV brake junction? - Alfa Romeo Bulletin Board & Forums
post #1 of 17 (permalink) Old 09-08-2012, 10:50 AM Thread Starter
Is this a standard brake 5 way junction box?
I'm having a helluva time threading a replacement brake line in there. Guessing the threads are stripped. It was very difficult to remove the stock line. Threads are the same on the replacement line. I think the threads are a M10x1.00, but I don't have a tap that size. Suggestions?
UngaWunga is offline
post #2 of 17 (permalink) Old 09-08-2012, 11:40 AM
flivesay's Avatar
Undo the box from the firewall--gives you a little wiggle room. Mine was tough to get all lines started. i ended up putting the line from underneath on the box first while it was removed from the firewall, then eventually got the rest
Frank Livesay Huntsville, AL
Green Alfa - 68 Canadian 1750 Spider Veloce (driver)
White Alfa - 68 Euro 1750 GTV (needs a refresh)
flivesay is offline
post #3 of 17 (permalink) Old 09-08-2012, 02:01 PM
Trained (ex)Professional
1953-2018 RIP
papajam's Avatar
Yes, that is the correct 5-port junction for a Euro 105 with single circuit brakes (1 port each for the 4 brake lines and one port for the brake light switch). The brakeline fitting size is 3/8" x 24 and I think the light switch is a 1/8" x 27 NPT.
And to provide even more wiggle room, loosen the other lines before removing the block from the firewall.
The two visible brakelines have already been replaced I see.
papajam is offline
post #4 of 17 (permalink) Old 09-08-2012, 03:29 PM Thread Starter
Its not M10x1.00? looks very close to that.
post #5 of 17 (permalink) Old 09-08-2012, 04:25 PM
USTA BE AN AD-MIN
ossodiseppia's Avatar
I wouldn't want close when it comes to brakes. The threads are English units.
ossodiseppia is offline
post #6 of 17 (permalink) Old 09-08-2012, 04:36 PM
1953-2018 RIP
papajam's Avatar
Yes, at 9.525 x 1.06, a 3/8 x 24 would indeed look very close to an M10 x 1.0. Another clue that they're 3/8 24 are the flats on the nuts of the replacement brakelines in the pic that take a 3/8" wrench (the correct 3/8 24 nut, available here, takes an 11mm wrench).
papajam is offline
post #7 of 17 (permalink) Old 09-08-2012, 06:20 PM Thread Starter
Good to know. Thanks.
post #8 of 17 (permalink) Old 09-11-2012, 06:56 PM Thread Starter
I cannot get the new line threaded into the junction. It just won't start. Time to go get a tap and clean up the junction threads.
post #9 of 17 (permalink) Old 09-12-2012, 05:28 AM
kengta's Avatar
Be careful, retapping a damaged thread may (will likely ) remove and cut away metal and thus weaken the thread holding power. Not something you want to do on a braking system, I suspect. Unfortunately I can't offer a good alternative other than to get an other block with good threads.
FWIW
Ken
Ken Geiger, Toronto
1965 GTA, RHD, Stradale
ex- 1965 GTA, RHD, Corsa, Trans/Am 66-72
1970 Giulia Super (CDN Spec)
1976 1600 GTj (Italian Spec)
2000 Catalina 320, Hull #765 Northern Dream
2001 BMW Z3 3.0i
kengta is offline
post #10 of 17 (permalink) Old 09-12-2012, 06:18 AM Thread Starter
Yup, I know. This is the last resort before asking around for a used junction block.
Are there new blocks that have 5 ports with the same thread pitches out there? Didn't see anything on the Summit racing site, IAP or Centerline.
This, of course, would be the ideal time to switch to a dual circuit system. But I really don't want to do that work now. This is the last thing to do before I can drive the car.
post #11 of 17 (permalink) Old 09-12-2012, 06:28 AM
USTA BE AN AD-MIN
Yes, running a tap in can really make a mess of things. There is something called a thread restore kit. I have a Craftsman brand one that is identical to the high priced SnapOn.
These can be found on Ebay. However, I do not know if the kit contains the correct size "tap".
post #12 of 17 (permalink) Old 09-12-2012, 06:56 AM
Your problem may be the nut.
Check the recent thread in the Giulietta forum.
Joe
jkbartusek is offline
post #13 of 17 (permalink) Old 09-12-2012, 04:06 PM
flivesay's Avatar
Did you keep the original fittings? Try one of those and see if it fits. I just refit the old fittings to the new line. If it fits--probably not your threads
flivesay is offline
post #14 of 17 (permalink) Old 09-12-2012, 08:13 PM Thread Starter
old one doesn't fit. Tried that.
post #15 of 17 (permalink) Old 09-12-2012, 08:35 PM
PSk
I'd purchase another second hand one from a wrecker. Surely won't cost much and we are talking brakes here, plus brake fluid leaks make a huge mess to the rest of your car .
Throw it in the bin IMO.
'71 1750 Series 2 GTV:
PSk is online now
