Oil Vapor Separator Horror Show Pt 1 - Page 13 - Alfa Romeo Bulletin Board & Forums
 6Likes
post #181 of 200 (permalink) Old 01-31-2011, 08:07 PM
never mix your 'personal' photos , with car photos( still learning about my digital camera).. i am now making a page in my p.c. for ' alfa romeo' photos... sorry agian
anyone can buy a Porsche, only Drivers drive a Alfa Romeo
bianchi1 is offline
post #182 of 200 (permalink) Old 06-13-2013, 07:52 AM
Hi
I've been reading this discussion for a while and have never went to the end, sorry.
On the web there are plenty of papers about cyclonic separators which are widely used in the industry.
I think it's interesting to look at the following product description, under the name:
Oil Mist Separator X-CYCLONE® 2.1 – english - Reven-usa.com
On page 7 there is explanation how they create micro-cyclones to separate oil from air.
Here is the link, not sure it will work, you can search for the name above:
http://www.google.fr/url?sa=t&rct=j&...PqtwLw&cad=rja
The next link points at a helical separator, the idea being to help the mixture to flow around the center line:
http://www.google.fr/url?sa=t&rct=j&...ri6FMA&cad=rja
So would not we just use a metal tube shaped in a cyclone that spirals down inside a can ?
alpa is offline
post #183 of 200 (permalink) Old 08-18-2013, 04:04 PM
grizzly's Avatar
Bumping this again. Noticed Centerline now has replacements for sale (though on back order) In all these pages never saw - WHAT THE HECK IS EVERYONE USING FOR HOSE? :-)
David Griszkauskas
Old Stuff:
1988 Spider Graduate
1980 Honda CX500 (cool..), 1970 Harley Sprint
Aš nesuprantu
grizzly is offline
post #184 of 200 (permalink) Old 08-18-2013, 04:51 PM
Shiraz1965's Avatar
Originally Posted by bianchi1 View Post
.. at least it's not a british car.. lights go like this.. dimm, flikker, off..
Which explains why Brits drink their beer warm; Lucas also made refrigerators......
Marc
1980 Spider, 1997 Fiat Coupe 20VT, 1965 Giulia TI, 1971 Spider 1300 Junior
Shiraz1965 is offline
post #185 of 200 (permalink) Old 05-08-2014, 09:40 AM
Vic
Vic's Avatar
OVS Element
Is there a source for a replacement OVS Element? If not, what are the specs for the steel wool substitute?
1982 Spider
Vic is offline
post #186 of 200 (permalink) Old 05-08-2014, 02:28 PM
gigem75's Avatar
My 02cents is that if the OVS has oil to catch there is to much blow by and there is a ring problem. With a healthy motor the oil should be measured in drops. If there is much more than that especially after highway runs above 4000 there will be more than even a healthy OVS can catch.
currently
2017 Giulia Q4
74 GTV restored daily driver
the ones that got away:
1962 Giulietta Spider normale
1965 Giulia Sprint normale
1972 GTV
1974 GTV
1974 GTV
1977 Spider
1974 Spider
gigem75 is offline
post #187 of 200 (permalink) Old 05-08-2014, 02:59 PM
kcabpilot's Avatar
The OVS is part of the PCV system and if either the dipstick seal or the oil filler cap gasket are bad it will create an air leak into the crankcase which will result in a higher flow rate of vapor to the canister. The idea of the system is to maintain a lower pressure in the OVS than in the crankcase so that there is positive ventilation at all times but properly sealed there isn't going to be a great amount of flow and therefore only a very small amount of oil vapor for the OVS to deal with. The priming of the drain-back line is also a part of that dynamic seal.
Paul - 1972 Spider - (2)1991 164S's - 1983 308 - 2001 Discovery - 1997 F350
kcabpilot is offline
post #188 of 200 (permalink) Old 05-09-2014, 04:42 PM
84FLVeloce's Avatar
I used stainless steel pot scrubber from a restaurant supply store. The idea is to have lots of surface area, but large enough ribbons of material that wont get sucked through vacuum lines into a cylinder. As coarse of steel wool as you can find, and stainless is important to keep rust away.
It works well in my homemade ovs. I have 64 or so k miles on my motor, other replies are correct, amount of oil caught and returned is minimal. I clean mine out every couple years.
Phil in FL
84 Spider
08 Tundra
92 Nighthawk 750
84FLVeloce is offline
post #189 of 200 (permalink) Old 08-24-2014, 08:38 AM
farina's Avatar
I just started working on my 87 Spider,I've been going through all the components under the hood. I got to the oil separator. Clogged and not designed to be opened, as all you Alfa people know. Your solution made my day thank you so much, now back to work.
farina is offline
post #190 of 200 (permalink) Old 08-24-2014, 09:24 AM
Stevew's Avatar
Location: Carson City, NV Class Champion Reno SCCA 2018
Great! Everyone here luvs happy endings, almost as much a pictures!
That's what the Forum is all about!
Now fill in your signature line and you will become an official member, in good standing. :-)
Best wishes!
Steve Waclo Carson City, NV; '87 Spider QV, ES Champion, 2018 Reno SCCA (125k);'93 Honda Nighthawk 750 (105k);'03 GMC Sierra SLE 2500HD Turbo Diesel (155k);'08 Altima Coupe 3.5SE, 6sp (125k)
Stevew is offline
post #191 of 200 (permalink) Old 12-11-2016, 07:37 AM
dhayes5's Avatar
Question for Alfanuts.
You soaked the OSV in paint thinner and cleaned a while back. Have you checked it lately? Was cleaning as you described effective?
Just bought a '77 spieder with 23k original miles. Have not delved into this beyond the bottom hose which had some black crud in it. Figured I would do as you did and clean all of this system.
dhayes5 is offline
post #192 of 200 (permalink) Old 12-11-2016, 11:40 AM
spiderserie4's Avatar
you can bet your bottom dollar, it hasn't been cleaned in 23k miles
yes. I do it every year (max every two)
Pretty clean now.
Alfa recommended cleaning it every few thousand miles (read this somewhere, but can't find it again, might even be in my WSM or a TSB maybe)
edit: oops sorry, question was for alfanuts.......
spiderserie4 is offline
post #193 of 200 (permalink) Old 12-11-2016, 04:16 PM
Born Again Boarder
Anfanuts's Avatar
I've run several Euro carb'd cars where the breather heads straight to the "banana style" air cleaner, no OVS, no oil return, and I have never found any oil stain on the air filter element. Seems like this oil return line and need is overblown.
shayes5 - I R&R'd it a 2nd time a few years later and it was pretty clean. It's been a few years now and due again, but not many miles put on annually.
Anfanuts is offline
post #194 of 200 (permalink) Old 12-12-2016, 02:59 AM
dhayes5's Avatar
Thanks for the reply - into the paint thinner it goes this week. Gives me something to work on while the TA is with Wes Ingram getting rebuilt.
dhayes5 is offline
post #195 of 200 (permalink) Old 12-12-2016, 07:24 AM
If you go back to the 5/9/2012 topic of new OV separator there is a link to someone who was making them. I bought and installed one and it is working fine. Others did the same.
Michael Squeo
87 Graduate
enzobindo is offline
