Front Sway Bar Drop Link Orientation - Alfa Romeo Bulletin Board & Forums
post #1 of 5 (permalink) Old 10-04-2019, 11:10 PM Thread Starter
crackie's Avatar
I have earlier style press-on sway bar drop links like below. I am putting them on a stock sway bar that didn't have drop links installed on it, so I have no reference for the angle at which the new drop links should be installed.
Is there anyway to figure this out on the bench? Or do I need to install the sway bar on the car and then see what angle the end links should be at, then remove the sway bar again and press on the drop links?
Rather not do double work, but can't find a spec for the drop link angle.
Thanks!
--Scott
Current: 85 GTV6, 69 Duetto, 17 Giulia, 74 GTV
Past: 65 Giulia Sprint GT, 77 Alfetta, 79 Alfetta, 87 Milano Gold, 74 GTV (Euro)
crackie is offline
post #2 of 5 (permalink) Old 10-05-2019, 06:31 AM
Andrew's Avatar
In the picture above, the left side goes at the bottom. So when installed, the strut angles towards the rear of the car.
Andrew
Andrew is offline
post #3 of 5 (permalink) Old 10-05-2019, 10:36 AM Thread Starter
crackie's Avatar
Thanks for that Andrew. Let me clarify my question a little better.
Where I am stumped is what the angle of the drop link needs to be in respect to the sway bar itself. If memory serves, once I press the link on it will not rotate on the sway bar. As such I have to make sure angle is correct so that the bottom part of the link can be in the right position to connect to the wishbone below.
Or maybe I am misremembering. Maybe the link can still be made to rotate a bit (rubber mallet?) once on the sway bar to mate up with the wishbone?
Thanks.
--Scott
crackie is offline
post #4 of 5 (permalink) Old 10-07-2019, 06:24 PM
61SS's Avatar
Thanks!
First, the drop links should be a press fit onto the sway bar so it is not adjustable later.
I am about to do this now. I just installed the rear sway bar. For that one, rather than try to measure an angle I measured the distance from the bar where it crosses the car (in front of the truss) to where the drop link attaches to the trailing arm... basically measuring the length of one leg of a triangle. See the red line in the image. This worked great in the rear. When I put the assembled sway bar in place the drop links were in exactly the right location. I wonder if there is a way to apply that idea to the front... rather than measure an angle, maybe measure the distance between the pins on the lower A arms and align the drop links on the bench so they are at that distance. I hope that makes sense!
Current: '69 Spider under reconstruction. Former: 56 Giulietta Spider, 61 Giulietta SS, another '69 Spider, 2600 Coupe paperweight, two GTV-6, 164L, 164S
61SS is online now
post #5 of 5 (permalink) Old 10-07-2019, 07:41 PM Thread Starter
crackie's Avatar
Thanks - this is super helpful. I haven't done this job in 20 years and I was pretty sure that they were press fit, so confirming that helps a lot. And your suggestion above for measurement sounds like a good approach. And I will have the same to do on the rear anyway, so directly applicable to that.
It'll be a couple years until these find their way on to the car, so will pocket this thread until then. I am trying to do as much on the bench as possible for easy install later, but sounds like this needs to be done when actually installing on the car.
--Scott
crackie is offline
