Thermostat Housing (and coolant drain plug) Woes - Alfa Romeo Bulletin Board & Forums
 4Likes
post #1 of 23 (permalink) Old 09-15-2019, 05:48 AM Thread Starter
Car was blipping past 212 on the gauge a few days ago on the drive to work, so I decided to start with a coolant flush and thermostat replacement. Workshop manual states the thermostat on manifold is to be torqued to 25.3 to 29 ft-lbs. Well I got out a torque wrench and got started and tore one of the bolts in half. It was pretty worn out so I tried a new bolt. Something still didn't feel right, and before I got to 25 ft-lbs I removed the bolt and checked the intake manifold block to find I had stripped a bit of the threads already - what am I doing wrong?
While I'm at it, is there a proper torque spec for the drain plugs on radiator and block?
stevespiderguy is offline
post #2 of 23 (permalink) Old 09-15-2019, 06:10 AM
I feel your pain...a simple project gone to hell!!
Hopefully, some experts can chime in!!
Are you sure your specs are correct? in-lbs vs ft-lbs?
I'm sure an expert can help
Good Luck
Paul
PS..How about you flush the radiator?
azALFAowl is offline
post #3 of 23 (permalink) Old 09-15-2019, 06:52 AM
SkiBum's Avatar
Torque wrench may need to be calibrated too... hopefully you will be able to run the appropriate tap through there and save the threads...
SkiBum is online now
post #4 of 23 (permalink) Old 09-15-2019, 12:07 PM
not2old4toys's Avatar
I seldom torque bolts, especially steel into aluminum. Torquing steel nuts on steel studs is ok. Head nuts, bearing caps, flywheel, suspension, and the like is good. This is just my take after 50+ years of working on Alfa's. Tighten evenly and snug. If there is a gasket present a good firm tightening should be sufficient. Use an alternating pattern like you do on lug nuts and draw down in stages.
Cheers, Jon
Present:
1967 Spider
1974 GTV (1969 Tribute)
1993 Spider ( project)
2018 Stelvio
Past:
1964 Giulia Sprint. 1966 Giulietta 101 Sprint
1967 Super 1968 GTV 1974 Berlina
1979 Alfetta Mille Miglia 1987 Milano
Non Alfa:
1953 MGTD 1958 TR3 1962 AH 3000 MKII
1969 AMX
not2old4toys is online now
post #5 of 23 (permalink) Old 09-15-2019, 12:30 PM
SkiBum's Avatar
Yeah, those torque values in the shop manual are just for show.... But after you have wrenched a lot you get a feel for torque in your hands. You also get a feel if something is wrong, dirty threads, cross threaded, etc. It is always wise to keep a tap and die set around to clean stuff up when needed, a properly calibrated torque wrench becomes more accurate too. Another tid bit, always back off your torque wrench when done using it..
post #6 of 23 (permalink) Old 09-15-2019, 02:48 PM
divotandtralee's Avatar
Helicoil and forget about torque..3/8" ratchet gripped half way down the hand using WRIST action is enough. Once you compress the gasket the job is done.
divotandtralee is online now
post #7 of 23 (permalink) Old 09-20-2019, 08:58 AM Thread Starter
Friends, I believe i had read something on the order of 25-30 ft-lbs. I don't have the book in front of me at the moment, but now I'm not sure, maybe it was 25-30 in-lbs. I will confirm this evening. Fortunately the damage was not excessive, it felt wrong in my hands so I didn't dare finish tightening and so the holes are not fully stripped, just one thread perhaps.
I'm always afraid when I tighten a drain plug by hand, or even the thermostat cover with the gasket I can visually see is slightly compressed, that I have not done so to the correct tightness. Is there not a great risk of the plug falling out?? Having drove a car while the wheel has blown off on the highway (those kids in auto tech never listen, hitting everything with an impact socket), I am especially cautious as I want to do the best job possible.
post #8 of 23 (permalink) Old 09-20-2019, 09:27 AM
If it ain't leaking leave it alone .. if it is leaking ..tighten it some more until the leak stops
post #9 of 23 (permalink) Old 09-20-2019, 11:08 AM
Gubi's Avatar
I don't think the problem is that you used a torque wrench, I think the problem is you used the wrong spec. IIRC it's around 10 ft-lbs.
These guys telling you not to use a torque wrench have no idea what they're talking about. If there's a spec, use a torque wrench. Just use the right spec.
1974 GTV
1991 Spider
Former: 1987 Milano Gold
Gubi is online now
post #10 of 23 (permalink) Old 09-20-2019, 01:30 PM
Gubi, with all due respect, Brake Bleeders have a torque setting. You must be the only person I know who uses a torque wrench on them if what you say is true.. It is not a sacrilege not to use a torque wrench on something as basic as the subject. Ga nite, Chet.
post #11 of 23 (permalink) Old 09-20-2019, 01:34 PM
I posted a fix, for the oem t stat, modification.. just dermal tool work, and you can use a reg. t stat in the housing.. check my name here, and t stat modication
bianchi2 is offline
post #12 of 23 (permalink) Old 09-20-2019, 01:49 PM
Gubi's Avatar
Never seen a spec for the Alfa bleeders, but ze German car zat ze wife drives has a brake bleeder torque spec, and I sure as heck use a torque wrench to tighten them. That way I know they're properly tight and I'm not going to snap one. Doesn't add any time for me to do the job right.
I mean, you can work on your car how you want, but maybe don't give other people bad advice. People - even experienced mechanics - are REALLY BAD at judging torque by hand. I've got plenty of experience turning bolts, but if there's a published spec I use a torque wrench: to do otherwise is just to be ignorant or lazy.
If your thermostat leaks, how do you know if the bolts are loose or if the gasket is bad? Just tighten it some more, and if you strip it then the gasket was bad? LOL.
1974 GTV
1991 Spider
Gubi is online now
post #13 of 23 (permalink) Old 09-20-2019, 01:53 PM
Gubi's Avatar
I would just use a helicoil. It should be pretty easy in that location, and it'll be a lot stronger than the original aluminum so you won't have to worry as much about stripping it again.
1974 GTV
1991 Spider
Gubi is online now
post #14 of 23 (permalink) Old 09-20-2019, 03:25 PM
I'm out.. the torque setting on bleeders is 0.14 -0.25 Ft-lbs..Knock yourself out. Unsubscribed.. Gubi this is a pissssssing contest ina friggging gale. You win.
post #15 of 23 (permalink) Old 09-20-2019, 04:34 PM
Gubi's Avatar
Whatever. Anyway, those numbers seem really low given that ze German car specs 6-9 ft-lb (though admittedly those are somewhat larger M10x1 bleeders.)
Steve, I'm afraid I can't find a torque spec for the thermostat for the earlier Spiders. My S4 spec's 7.4-11.8 ft-lb but it uses a different thermostat. It may be in the S3 service manual which I do not have.
1974 GTV
1991 Spider
Gubi is online now
