Duetto steering wheel centercap removal - Alfa Romeo Bulletin Board & Forums
 1Likes
  • 1 Post By not2old4toys
post #1 of 10 (permalink) Old 09-08-2019, 02:30 PM Thread Starter
I purchased an original three spoke wheel with the cap in place; I'm ready to put the wheel on the car but this cap
is driving me nuts- I can slip butter knives in at several places and lift it a bit but I really don't want to break it- these things don't grow on trees. What is the magic technique? Would soapy water help? Maybe some silicone spray?
Mark
markba633csi is offline
post #2 of 10 (permalink) Old 09-08-2019, 03:57 PM
Ranz's Avatar
Some silicons spray or other lube won’t hurt.
The cap is held in by 3(?} small pieces of spring steel pressing outwards against the hub bore. These might drag a little, resisting your pressure with your ‘butter knife’, but shouldn’t resist or catch sufficiently for you to damage anything, provided you are reasonably gentle.
Once your sharp blade has lifted the edge of the cap a little, slip a flat blade screwdriver inwards towards the centre and twist gently. As the cap rises, use a bigger screw driver. Work at several places around the edge.
Ranz is offline
post #3 of 10 (permalink) Old 09-08-2019, 07:09 PM Thread Starter
Thanks Ranz I'll try a little lube and a progressive lift approach with multiple utensils
At 50+ years old this plastic has to be pretty brittle- taking it easy as possible
post #4 of 10 (permalink) Old 09-10-2019, 05:04 PM
divotandtralee's Avatar
I always used a flat blade tangentially on a gap between plastic and metal to spread the load of the prying tool.. In fact it isn't a bad idea to slide two thin knives between the hub you are trying to remove (plastic) and the wheel hub (metal).. then go to work twisting your lever/screwdriver between the 2 blades.
divotandtralee is offline
post #5 of 10 (permalink) Old 09-10-2019, 08:57 PM
Yachtman's Avatar
Is this your cap??
[B][I][U]Current[/U][/I][/B]
1984 Spider Veloce Deluxe
1969 GT 1300 JR
1969 1750 Spica Spider Veloce
1963 MGB
1952 MG TD
Others??!!!😃😃
Yachtman is offline
post #6 of 10 (permalink) Old 09-11-2019, 01:56 PM Thread Starter
Yep that's it- wish my dash looked that good LOL
Mark
post #7 of 10 (permalink) Old 09-11-2019, 04:02 PM
not2old4toys's Avatar
It's a compression fit.. there is a O ring in the wheel housing.
Gently pry with a non metallic tool. Harbor Freight sells trim removal kit.
markba633csi likes this.
Present:
1967 Spider
1974 GTV (1969 Tribute)
1993 Spider ( project)
2018 Stelvio
Past:
1964 Giulia Sprint. 1966 Giulietta 101 Sprint
1967 Super 1968 GTV 1974 Berlina
1979 Alfetta Mille Miglia 1987 Milano
Non Alfa:
1953 MGTD 1958 TR3 1962 AH 3000 MKII
1969 AMX
not2old4toys is online now
post #8 of 10 (permalink) Old 09-11-2019, 06:45 PM
Yachtman's Avatar
Just dig your fingers under it and pull it off. ����
1969 GT 1300 JR
1963 MGB
1952 MG TD
Others??!!!😃😃
Yachtman is offline
post #9 of 10 (permalink) Old 09-11-2019, 08:57 PM Thread Starter
Thank you Not2old that helps me a great deal- also explains the strange resistance I was feeling- definitely going to use some type of lube- also I can spray it in from the back thru the center since the wheel is off the car
Mark
post #10 of 10 (permalink) Old 09-12-2019, 09:33 AM
It should pry up very easily. If not, be prepared that some sort of modification has been done.
Present:
1967 Spider
2018 Stelvio
Past:
Non Alfa:
1969 AMX
