Solutions for Spider 2000 S2 not starting or firing? - Alfa Romeo Bulletin Board & Forums
post #1 of 2 (permalink) Old 08-29-2019, 06:26 PM Thread Starter
I purchased 1974 Spider 2000 a few months ago. After replacing fuel system and ignition system I got it running after it had been sitting for 16 years. We took it for a test drive can home, degreased the engine and parked it in the garage. It sat for about a week and then I tried to start it an it had no spark.
Here is what I have tried.
*Before this problem I had install a new bosch blue coil and Vicks electronic ignition distributor.
1. Light tested and found power on positive and negative side of the coil.
2. Swapped coil with one from my Sunbeam Alpine just to see if new coil was bad.
3. Ordered new electronic Distributor from Vicks thinking the other new one was maybe defective.
4. Set engine to TDC, Rotor button points to #1 cylinder
5. Checked firing order. #1 plug wire is right above rotor button pointing to #1. Order on cap is 1,3,4,2 going clockwise
6. I made new red and black wires that go from the coil to the distributor.
7. Installed new coil wires
8. Green/Black wire on - side of coil light tested and has power when the ignition switch is turned on.
9. Coil wires. Red on +, Black on -, Green/Black on -
WHAT I'm I MISSING? I don't understand why the system is not working. Is there another module or sensor somewhere?
A side note... I am not getting fuel in the cylinders. The fuel pump is running and I have 19 PSI just past the front filter. It is a spIca system. I am focused on getting the car to fire first but just wanted to mention it in case some strange way its related.
Any help would be appreciated because I am pulling my hair out.
74Alfaman is offline
post #2 of 2 (permalink) Old 08-29-2019, 06:50 PM
not2old4toys's Avatar
Degreased the engine!! Did you cover the electrical parts. Ie distributor, coil? Spray some electromotive or similar inside the cap. I would start there first. Then move to spark, fuel, air.
Cheers, Jon
Present:
1967 Spider
1974 GTV (1969 Tribute)
1993 Spider ( project)
2018 Stelvio
Past:
1964 Giulia Sprint. 1966 Giulietta 101 Sprint
1967 Super 1968 GTV 1974 Berlina
1979 Alfetta Mille Miglia 1987 Milano
Non Alfa:
1953 MGTD 1958 TR3 1962 AH 3000 MKII
1969 AMX
not2old4toys is offline
