Cam Timing? - Alfa Romeo Bulletin Board & Forums
post #1 of 8 (permalink) Old 08-24-2019, 10:17 AM Thread Starter
Member
Cam Timing?
Lou
390377 is offline
post #2 of 8 (permalink) Old 08-24-2019, 10:47 AM
spiderserie4's Avatar
can you confirm at TDC on compression, with timing mark aligned and cams on those marks, the rotor is pointing towards front of car? (that is #1)
or pointing aft? (that is #4)
Alfa cams have 2 marks, 180 opposite.
Distributor put 180 out? (but then the rotor on TDC compression stroke would point aft to cyl#4)
Cams switched over?
spiderserie4 is offline
post #3 of 8 (permalink) Old 08-24-2019, 11:21 AM Thread Starter
Member
So I may have spoken too soon. Upon replacing the dist cap, the car wouldn't start. Starting over, and putting the little nub in the cap in the little indent and the car runs fine. But that means I thought #1 was about 2 Oclock, but is actually 11 oclock. Something is not right, but I'm not sure what. Not sure why the rotor would point to #3 at TDC, more likely the sun addled my brain. At least I got a new cam cover gasket out of the deal. Have to start over , and redo all my settings. then I'll check back. Sorry for the false alarm.
390377 is offline
post #4 of 8 (permalink) Old 08-24-2019, 11:28 AM Thread Starter
Member
I am wondering if the dist was put in 180 degrees out. The other possibility is that old eyes looking into dark holes from bright sun saw what they expected to see. It running right now, so I'll start from scratch next time.
390377 is offline
post #5 of 8 (permalink) Old 08-24-2019, 02:05 PM
Originally Posted by 390377 View Post
...but is actually 11 oclock. Something is not right, but I'm not sure what. Not sure why the rotor would point to #3 at TDC...
the rotor is pointing to # 4 at TDC (that's about 11 o clock)
your distributor has been put 180 out during an engine rebuild.
Car will work fine as long as no #1 lead is clipped into position #4 of the dist. cap, then follow through "clockwise" with leads for cyl #3, #4, and #2.
(Firing order is 1-3-4-2, and cylinders are numbered 1 to 4 from front to back of engine)
post #6 of 8 (permalink) Old 08-25-2019, 03:55 AM Thread Starter
Member
Yes, but I am beginning to suspect that I turned the cap 180* when I removed it. Therefore I pointed the rotor 180* out, at #4 rather than #1. These are dumb rookie mistakes. It is "amazing" how much you learn when you do something every day vs. how much you can forget when you don't do something for 30 years.
I do appreciate your help though as it helps to clarify my thinking.
lou
390377 is offline
post #7 of 8 (permalink) Old 08-25-2019, 08:01 AM
Richard Jemison
Alfar7's Avatar
Distributor timing
Just FYI: It matters not where the position is for #1 relative to front/back or sides, as long as at TDC for #1 you identify where the rotor is pointing, and use the cap terminal at that position for the #1 spark plug wire...
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is online now
post #8 of 8 (permalink) Old 08-25-2019, 09:41 AM Thread Starter
Member
Thanks Richard. What I am trying to say is that I screwed up royally and set the engine 180* out because of A) stupidity, B) senility, C) brain fade, take your pick. There is nothing wrong with the engine, just me.
Lou
390377 is offline
