no Heat anymore.. - Alfa Romeo Bulletin Board & Forums
post #1 of 9 (permalink) Old 08-23-2019, 11:46 AM Thread Starter
scagliog's Avatar
no Heat anymore..
Hello, Spider 1982
after a successful transmission + clutch + axle bearings +...+.. replacement all works great.. except I don't seem to get any heat from the heater anymore. It was kind of weak before, now is really almost not working. Any thermostat valves somewhere for the heater? ANy good pointers ?
The fan ( 1 speed ) is working..
Giuseppe
"alfista"
scagliog is offline
post #2 of 9 (permalink) Old 08-23-2019, 01:06 PM
spiderserie4's Avatar
no heat is generally the heater control valve (bolted to the heater itself, look up under the dash, roughly above the gas pedal)
Bit of a pain to swop it out because its awkward to get at (easier if you remove the driver's seat and lie on your back!), but can be done....w/o AC is easier.
Took me a good hour first time I did it. Then the new valve failed a week later spewing hot coolant onto my feet, so had to do it again...2nd time around took me less than an hour, but not much less!...
photo here
https://www.alfabb.com/bb/forums/5242282-post1.html
spiderserie4 is online now
post #3 of 9 (permalink) Old 08-23-2019, 01:09 PM Thread Starter
scagliog's Avatar
Thank you!
I think I need to take the seat out for another side project ... not too cold in California right now, but I was to figure it out.
Yes no A/C in my car.
Cheers,
Giuseppe
"alfista"
scagliog is offline
post #4 of 9 (permalink) Old 08-24-2019, 01:56 PM
its 101 today, you need heat?
bianchi2 is offline
post #5 of 9 (permalink) Old 08-24-2019, 02:00 PM
also a bad t-stat will cause a no heat problem inside the car.. fan working?
bianchi2 is offline
post #6 of 9 (permalink) Old 08-24-2019, 07:57 PM
alfaromeoblack's Avatar
Originally Posted by scagliog View Post
Hello, Spider 1982
Giuseppe
After a engine swap in my spider I had no heat too. Had to bleed the air out of the system. There is a bleeder bolt on top of the water pump. I did not did bleed my system, just ran the heater for a couple of weeks and the air worked its way out of the system.
Ken Smith
alfaromeoblack is offline
post #7 of 9 (permalink) Old 08-24-2019, 08:03 PM
Shakey's Avatar
While doing other work, I once accidentally put a kink in the heater hose, right at the firewall. It was hard to see from either side, but once I pulled it free, it was apparent what had happened.
-Kevin
Shakey is offline
post #8 of 9 (permalink) Old 08-24-2019, 08:44 PM Thread Starter
scagliog's Avatar
Thanks a lot!.... You know there is a bleeder bold on top of the plenum but for the love of God I was not able to move that.... so I might just check for kinks and run the heater for a while ...
Grazie!
Giuseppe
"alfista"
scagliog is offline
post #9 of 9 (permalink) Old 08-25-2019, 11:23 PM
The nut on the rear of the intake manifold can be used as an air bleed. On older 105's it had a real screw in bleed valve. Now just a cheap nut.
Robert
60sRacer is offline
