'77 with SPICA won't run right - Page 2 - Alfa Romeo Bulletin Board & Forums
 9Likes
post #16 of 26 (permalink) Old 08-25-2019, 10:37 AM
Norseman50's Avatar
Originally Posted by Boccaccia View Post
Here are the culprits. Rotor is hitting Cap from below.
I don't know why.
Both rotor and cap are "Bosch"?
Edward
'88 Quad - "Claudia"
Norseman50 is offline
post #17 of 26 (permalink) Old 08-25-2019, 10:57 AM
Marelli
Boccaccia likes this.
2011 Jaguar XKR
alfaparticle is online now
post #18 of 26 (permalink) Old 08-25-2019, 01:44 PM
spiderserie4's Avatar
I don't know why.
maybe mismatched rotor and cap?
or, rebuild back then wasn't so hot and there is play in the shaft?
(you say it never ran right since you got the rebuilt dizzy from centerline.....I'd have thrown it back at them, but now its too late)
there is also this (though yours is not a plex)
https://www.alfabb.com/bb/forums/ele...nce-alert.html
spiderserie4 is offline
post #19 of 26 (permalink) Old 08-25-2019, 08:06 PM
Roadtrip's Avatar
Are you sure that the rotor is oriented correctly and is fully seated on the advance weights?
CSS. For info, it anyone is unsure about the adjustment of the CSS, it should be about a quarter inch from the pump casting to the bottom of the CSS.
Microswitch. LOL. Good luck changing a microswitch in-situ.
The microswitch can easily be tested with an ordinary test light connected between the wire to the FCS and ground. Run the engine up to about 3000 rpm and snap the throttle closed. The light should come on, then go off as the engine decels through 1600-1300 rpm and recovers to idle.
Relay crank. If you need to check the relay crank, PM me and I can loan you the jig to check it and set it if necessary.
John Stewart
74 Spider
91 164S
Roadtrip is online now
post #20 of 26 (permalink) Old 08-27-2019, 02:34 PM Thread Starter
Boccaccia's Avatar
Crap.
I was wrong about the distributor cap and rotor colliding. I measured the pieces with a micrometer and there is plenty of space between the top of the rotor and the cap.
Reinstalled, checked timing and the engine still runs like crap above 3500 rpm. It sounds ragged, and when I use my timing gun, the mark on the crank jumps all over the place once the revs get up.
Timing advances normally up to 3500ish, but then starts jumping around all jittery.
Plugs are new.
Wires are six years old but have less than 5k on them.
Same with the cap and rotor.
Diz is rebuilt.
Ignition system is Pertronix.
Coil is Bosch Blue and recent.
Spark is strong.
Steve Bock
'77 Spider with SPICA
Boccaccia is offline
post #21 of 26 (permalink) Old 08-27-2019, 06:05 PM
I know you said you've replaced the plugs twice but what you are describing is exactly what i experienced with my SPICA 2L recently. Brand new NGKs, i noticed erratic pulsing when using the timing light. You might try using the timing on each wire and see if you have a consistent pulse.
BTW, the Centerline dizzy i have uses a Pertronix module. While I've not had trouble with the dizzy i have had a number of Pertronix go bad on me....
gprocket is offline
post #22 of 26 (permalink) Old 08-27-2019, 07:49 PM
There have been stories of bad Bosch coils made in Mexico. A failing coil could cause your symptoms. What coil resistance is specified for your distributor?
2011 Jaguar XKR
post #23 of 26 (permalink) Old 08-29-2019, 04:42 AM
Have you checked for arcing spark? You need to do this in a pitch-black environment. At night, lights off, a heavy blanket or tarp over the engine compartment. Look for arcing at coil, dizzy cap, along secondary ignition wires and their connection to the spark plugs.
ALFA ANDY
andylarry is offline
post #24 of 26 (permalink) Old 09-19-2019, 01:38 PM Thread Starter
Boccaccia's Avatar
Thanks for the comment - what was your solution? Another set of plugs?
Steve Bock
post #25 of 26 (permalink) Old 09-19-2019, 01:41 PM Thread Starter
Boccaccia's Avatar
My coil has about 1000 miles on it. It's the blue Bosch from Centerline.
My diz is a Marelli S103B. I don't know the recommended resistance.
Steve Bock
post #26 of 26 (permalink) Old 09-25-2019, 09:43 AM
Replaced the plugs and filters - runs like a champ now...
gprocket is offline
