Bosch L-Jetronic cold start issue - Alfa Romeo Bulletin Board & Forums
 3Likes
post #1 of 25 (permalink) Old 08-17-2019, 02:47 AM Thread Starter
Send a message via Skype™ to levp
1984 Spider with Bosch L-Jetronic injection. Basically anything from 1982 to 1987 is the same, I think.
Cold start: starts well but dies after a few seconds unless I keep revs. After a minute or two the engine is able to idle without my help. Hot start fine.
My suspect is oxygen sensor, because my car is fitted with 1-wire sensor (without heating).
However, it seems like the problem started to appear once I've removed catalyst. It was all rotten inside and local rules don't require catalyst on such old cars.
I'd like to hear a confirmation that non-heated oxygen sensor could cause this problem before I fork out 100$ for a new one.
levp is offline
post #2 of 25 (permalink) Old 08-17-2019, 12:08 PM
John533i's Avatar
You can find a good write-up in the FAQ section on L-Jet issues. It could be cold start valve not spraying enough fuel, addition air valve stuck closed, not providing extra air, the thermotime switch, or it could be coolant sensors, one for ignition ECU and one for FI ECU.
Thats all I can think of off the top of my head...
John
alfabeach likes this.
86 spider Veloce
74 TR6
John533i is offline
post #3 of 25 (permalink) Old 08-17-2019, 03:43 PM
BB Janitor
ghnl's Avatar
Click the link in my signature to a page of info about the L-jet system in our cars.
I doubt the O2 sensor is the source of your car's problem. More likely is a non-functional AAV (Auxiliary Air Valve). The AAV is supposed to open to admit some extra air when cold. This increases the cold idle speed. A good work around is to install a manual AAV - basically a cable operated heater valve. You just have to remember that the manual AAV is self-closing (you have to close it yourself...). There is info about this in the Spider FAQ thread. BTW, it is best to not touch the throttle when starting an L-jet engine. Thus the importance of the AAV. At idle, the Throttle Position Switch tells the computer the throttle is at idle so it follows its programmed mixture settings. Once the throttle is open the computer tries to use the O2 sensor to adjust the mixture. But the non-heated (one wire) O2 sensor is usually not hot enough at idle for the O2 sensor to send a valid signal.
The Cold Start System consists of the Thermo Time Switch (TTS) and the Cold Start Injector (CSI). The CSI squirts a little extra fuel and is controlled by the TTS (not under computer control). The TTS sends power to the CSI for a few seconds (longer when cold, not at all when hot). A faulty TTS can either prevent the CSI from squirting when it should or allow to squirt when it should not. Info about this is in the Spider L-jet Diagnosis page.
pantera928 likes this.
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
ghnl is offline
post #4 of 25 (permalink) Old 08-18-2019, 07:09 AM Thread Starter
Thanks, will check both AAV and TTS.
Only last night I came around a working link to your brochure. Been trying to open your file for the past 2 months. Most of the links on this website are outdated. This is the link that worked for me: https://www.hpsimotorsports.com/l-jetronic--spider-
levp is offline
post #5 of 25 (permalink) Old 08-19-2019, 01:07 AM
spiderserie4's Avatar
yep, that is exactly the link in Eric's signature.
I saved it as a pdf on my desktop.
Apart from AAV/TTS checks, I'd also check the CTS, not just the ohms, but maybe remove it and clean the probe that sits in the water flow.
The Coolant temp. sensor is a critical componant that has to work correctly.
spiderserie4 is online now
post #6 of 25 (permalink) Old 08-20-2019, 02:21 AM Thread Starter
Ok, after reading it seems like the correct term should be "warm up issues". Will investigate further but any ideas are welcome anyway.
levp is offline
post #7 of 25 (permalink) Old 08-28-2019, 03:21 AM Thread Starter
I've checked both CTS and TTS and they appear to be fine according to ohmeter readings.
I haven't checked the AAV but I don't think it has much importance with temperatures over +30C.
So it has to be either rich mixture or malfunctioning O2 sensor.
levp is offline
post #8 of 25 (permalink) Old 09-18-2019, 02:16 PM Thread Starter
Gents, another update and request for collective mind:
I've turned the revs up a little via the regulator by the throttle, so usually once you start the engine keeps on working and doesn't die. Well, maybe once, but then it starts right away and doesn't seem to die once again.
Now the engine revs at around 900 rpm when cold, but when it gets to working temperature, the revs go up to 1200 rpm. Totally opposite of how it is supposed to be.
What do I do to fix it?
levp is offline
post #9 of 25 (permalink) Old 09-18-2019, 02:28 PM
Gubi's Avatar
Most likely your AAV is not operating properly. Remove and test per the L-jet article.
John533i likes this.
1974 GTV
1991 Spider
Former: 1987 Milano Gold
Gubi is online now
post #10 of 25 (permalink) Old 09-20-2019, 01:12 PM
John533i's Avatar
You will have to re-adjust your idle back down once you figure out the AAV, or it will always be high.
86 spider Veloce
74 TR6
John533i is offline
post #11 of 25 (permalink) Old 09-21-2019, 06:19 AM
you mean at the idle adjuster O-ring connector (X on diagram)?
or did you change things at the idle stop on the other side?
post #12 of 25 (permalink) Old 09-21-2019, 10:57 AM Thread Starter
That didn't help much. There is a screw on the other side of this intake. Turning that screw helped to gain some rpm.
levp is offline
post #13 of 25 (permalink) Old 09-21-2019, 11:33 AM
Gubi's Avatar
That is the throttle stop screw. You should not mess with that.
If the idle adjustment nut didn't do much, it means the o-ring in there is hardened and no longer flexing. It's a very cheap part and you should just replace it.
1974 GTV
1991 Spider
Gubi is online now
post #14 of 25 (permalink) Old 09-21-2019, 12:16 PM
yep. that screw is basically factory set on injection cars and shouldn't be messed with....hence the plastic 'no tamper' cap (which is/should be there from factory)
What you want is the butterfly to "just" be open a few thousandths when the throttle rests on the stop screw. Trouble is finding that point without factory tools, now you've messed with it.
When you got that correct, then you'll need to reset the TPS (to click just as you come off idle - use your fingers to move throttle, engine off, so you can hear the click!...or use a DVM to check ohms)
https://www.alfabb.com/bb/forums/spi...w-setting.html
as Tom rightly says, get a new O ring for the idle control.
Although originally it should be a small fat donut type thingy(!) this seems to work:
https://www.alfabb.com/bb/forums/car...placement.html
post #15 of 25 (permalink) Old 09-25-2019, 02:03 PM Thread Starter
Right.
So tonight I've cleaned the AAV. No change in behavior.
So I went on and adjusted the TPS to factory setting. That was easy.
But the car started to chock hard. I've tried to play with idle control valve. It didn't work out. On the way I've found that it's connecting tube was clogged with something. A new temporary tube didn't help.
So I've decided to pull it our and see what's the story of that donut inside. It was not where I'd expect it to be but ok...
I think the donut that I've found is way too far from an o-ring. Anyway. Since the hole was too small, I've enlarged up to 5 mm or so. Assembled everything back.
While now on warm engine the idle seems to be around 950 rpm, I have no possibility to add more rpm, which I think would be necessary on an engine with A/C unit. And I don't know yet how the cold start will be like.
I'm also not sure that substituting this donut with a simple o-ring pushed inside will work.
levp is offline
