Changing Fuel Injector hoses? - Alfa Romeo Bulletin Board & Forums
 3Likes
  • 1 Post By radamm
  • 1 Post By ghnl
  • 1 Post By Jack5j
post #1 of 8 (permalink) Old 08-15-2019, 03:12 PM Thread Starter
Hello all,
Does anyone have experience, or a resource to point me to, on how to change the injector hoses? The ones that are about 1-1/2" long between the fuel rail and the injectors?
I have a manual, but all it cryptically says is "Use a welder" at the metal bushing. The 'welder' pictured looks like an old soldering gun.
The car had a fire from a split hose, so I want to change all 4...without causing any new leaks.
Any help is GREATLY appreciated!
Thank you all.
Jack5j is offline
post #2 of 8 (permalink) Old 08-15-2019, 03:16 PM
radamm's Avatar
Yep, that's a soldering gun/iron. You would not want to knick the barbs on the fitting.
Jack5j likes this.
__________
Rick
MEMBRO LATO OSCURO
69 850 Spider (A fond college days' memory)
81 Spider Veloce
Downstate Illinois SNO Director
radamm is offline
post #3 of 8 (permalink) Old 08-15-2019, 03:39 PM
BB Janitor
ghnl's Avatar
Yes, I guess the translation made a 'soldering iron' come out as a 'welder'. The rationale is to melt through the old hose instead of using a knife which might nick the hose barbs leading to a leak.
The hoses have to be a specific size - 7.5mm ID. 1/4" is too small, 5/16" is too large. Remember to put the cup shaped washers on first - they keep the ends of the hose from mushrooming out.
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
ghnl is online now
post #4 of 8 (permalink) Old 08-15-2019, 04:15 PM Thread Starter
Can you explain the process? Is it melting the hose to the bushing? The replacement kits have no instructions and the picture is all that is in the shop manual. Do the new hoses and metal bushings just slide on and held with pressure?
Jack5j is offline
post #5 of 8 (permalink) Old 08-15-2019, 04:22 PM
BB Janitor
ghnl's Avatar
Heat up the soldering iron, melt through the hose until it releases its grip on the hose barbs (yes it is safe to use a hot soldering iron - but no open flames or lit cigarettes!). Cut the new hoses to length, make sure the cup washer is in position and push the new hoses into place. I put a drop of light oil on the hose barbs to make it easy to slide the hoses all the way on - I don't know if that is needed or not but it hasn't hurt any that I've done.
The short hoses that come with some of the 'kits' I've seen may be too short. I bought a few feet of 7.5mm ID FI hose and cut what I need from that.
The longer hose that goes to the Cold Start Injector has a hose clamp at one end & the cup washer at the other. It should be a proper FI style hose clamp - not a hardware store worm drive.
Jack5j likes this.
- - Eric
don't read this
- -~ 1981 GTV-6 ~
ghnl is online now
post #6 of 8 (permalink) Old 08-15-2019, 04:29 PM
sloboy89's Avatar
There's a camp that says to use the FI hose clamps on the fuel-injector hoses. Initially, I was not in that camp. Now, I am firmly in, as described in the cautionary thread below.
https://www.alfabb.com/bb/forums/spi...injection.html
Rich
'85 Spider Veloce
'17 Giulia Ti Sport
sloboy89 is online now
post #7 of 8 (permalink) Old 08-15-2019, 04:34 PM Thread Starter
THANK YOU!!! I have to go buy a "welder"! (I have only needed a battery operated one.)
The hose kits came from a well known supplier and are INDEED almost 1/4" shorter than what is on there. I will get fuel line, too!
Greatly appreciated, ghnl!
I just read sloboy89's thread...exact same here, except this one DID catch fire! I posted pics in my first post here. I just got the new wiring harnesses through the fire wall and can't let THIS happen again.
sloboy89 likes this.
Jack5j is offline
post #8 of 8 (permalink) Old 08-16-2019, 04:10 PM Thread Starter
Thank you all. I got the hoses off the rail and the injectors out and cleaned. They were very brittle, probably some from the fire but many certainly from age.
I'll start putting it back together tomorrow. Thank you again!
Jack5j is offline
