1986 Alfa Spider Quad Convertable Top Issue - Alfa Romeo Bulletin Board & Forums
post #1 of 3 (permalink) Old 08-15-2019, 08:35 AM Thread Starter
Junior Member
Is there a way to tighten up the front of the convertible (bow/rubber seal) top where it meets the top of the windscreen. there is a gap of about 1/2 inch or less from the center to about 10 to 12 inches to the left and right of the rear view mirror.
Thanks all
V/R
Chris
Crowe is offline
post #2 of 3 (permalink) Old 08-15-2019, 09:32 AM
BB Janitor
ghnl's Avatar
My guess is the top fabric is too tight - preventing the header from being able to fit snug against the windshield frame. Before disconnecting the fabric from the header (it is glued on with contact cement) you can try adjusting the top height to see if that will allow some slack in the fabric. Look where the top frame attaches to the body behind the door openings. Loosen those bolts and see if the frame will move downwards any.
The Conv Top Manual is posted here: https://www.alfabb.com/bb/forums/spi...tructions.html
(I am not sure if the mustache is a requirement...)
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
ghnl is offline
post #3 of 3 (permalink) Old 08-15-2019, 09:37 AM Thread Starter
Junior Member
Thank you sir ...first order of Business today …
V/R
Chris
Crowe is offline
