Door window issue - Alfa Romeo Bulletin Board & Forums
 2Likes
  • 1 Post By tremere613
  • 1 Post By ghnl
post #1 of 11 (permalink) Old 07-23-2019, 01:43 PM Thread Starter
Send a message via Skype™ to levp
Door window issue
Hi guys,
Spider 1984, with electric windows.
Half way up or down the window meets some sort of resistance and slows its movement. Sometimes simply stalls.
Tried to play with forward window track - didn't help.
Some observations:
1. The top forward pulley has substantial play on its axle in/out - about 1 mm. The bolt that holds it is tight.
2. Cable tension exists only in way that is correspondent to motion of the glass: i.e if the glass goes down, then there is no tension between top front pulley and the pulley at the door bottom. Once the glass goes up, then there is tension between those pulleys, but no tension between bottom forward pulley and the next pulley on top (middle pulley).
3. Probably pushing the forward window track and the vent window frame to the outside would help, but it seems like the angle at the bottom of the track doesn't have enough movement. And I don't see any other place for adjustment.
Any ideas how to fix this?
levp is offline
post #2 of 11 (permalink) Old 07-23-2019, 04:27 PM
alfaromeoblack's Avatar
Originally Posted by levp View Post
Hi guys,
Some observations:
It might be the wiring going through the door. Over time the wires weaken and not allow all the power to pass. Test with volt meter before missing with cable pulleys.
Sent from my iPad using Tapatalk
Ken Smith
alfaromeoblack is offline
post #3 of 11 (permalink) Old 07-24-2019, 01:38 PM Thread Starter
The power is fine. It's an alignment issue most likely, since while the window slows done significantly about 1/2 way either side, once past an inch or so the speed resumes to regular.
levp is offline
post #4 of 11 (permalink) Old 07-26-2019, 07:32 PM
Let me know if this diagram helps!
ghnl likes this.
tremere613 is online now
post #5 of 11 (permalink) Old 07-26-2019, 08:08 PM
BB Janitor
ghnl's Avatar
My guess (just a guess) is that the window might not be centered in the run of the cable. Meaning, the distance the cable can move is longer than the distance the window has to move. if the window is attached too close to one end or the other of the cable there can be some binding.
Try loosening the window to cable attaching bolts and see if you adjust the position of the window to be closer to the middle of the run.
There is a good sketch of the cable pulleys and attachment points in this thread: https://www.alfabb.com/bb/forums/spi...ht-window.html
alfaromeoblack likes this.
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
ghnl is offline
post #6 of 11 (permalink) Old 07-27-2019, 08:02 AM
Thank you for sharing, I have been saving all of your pictures and specs. It is becoming harder and hard to fine information about our cars.
Ken Smith
post #7 of 11 (permalink) Old 07-27-2019, 11:49 PM Thread Starter
Hopefully that will work. I've managed to loose only the forward attaching bolt yesterday and removed some slack of the cable there, but it wasn't enough. The second attaching bolt was turning with it's nut and it was getting really hot outside, so I left it till later. Will try to play with it again today.
levp is offline
post #8 of 11 (permalink) Old 08-03-2019, 03:32 AM Thread Starter
Update: I've loosened both nuts holding the cable to the glass. Played a little with glass and now it goes down really well, with good steady speed. All cables are neither loose nor too tight at any stage (window going up or down). However, the lifting movement is extremely slow. There is nothing that obscures window guides and with some push or pull it is possible to have window going up faster. But it's a power window, so it is supposed to go up without any help.
So, any idea where else to play? I think I've tried loosening all possible screws on the door...
What I did not try, however, is to try and play with window guides now, that the window goes down quickly. On the other hand, I'm not sure it would do any good.
levp is offline
post #9 of 11 (permalink) Old 08-03-2019, 06:00 AM
spiderserie4's Avatar
observe the felt in the tracks/guides whilst operating the windows....sometimes it works itself loose and starts moving up and down together with the window.
this then bunches up either at the top or the bottom and your window slows or even stops.
spiderserie4 is online now
post #10 of 11 (permalink) Old 08-03-2019, 10:05 AM Thread Starter
Checked that already. The felt is so old that it's packed flat on the track rubber. Haven't noticed any disturbance though.
levp is offline
post #11 of 11 (permalink) Old 08-17-2019, 02:39 AM Thread Starter
Update.
I've fiddled more both with window guides and window position on the cable and called it done.
In comparison to the other door this window slides now at even speed both up and down.
Driver's window, the one that I haven't touched yet, slides down very slow, but goes up much faster.
Well, one day I might open the driver's door and try to correct window position in there as well.
levp is offline
