New to me 1984 Spider Veloce - Page 4 - Alfa Romeo Bulletin Board & Forums
 14Likes
post #46 of 53 (permalink) Old 08-19-2019, 04:41 PM
SkiBum's Avatar
Looks familiar.... my spider sat for 17 years before I bought it.
SkiBum is online now
post #47 of 53 (permalink) Old 08-19-2019, 06:00 PM
I've the same car.
Intermittent and starter doesn't issues.
In the trunk, the battery connector on the long + cable up to the starter, was internally corroded at the connection.
It was impossible to see or inspect.
After trying everything else, and baffling my mechanic; he cut off, stripped back, and upgraded both battery terminals.
Fixed all my starter troubles.
;-D o n
Don Jamieson is offline
post #48 of 53 (permalink) Old 08-19-2019, 06:29 PM Thread Starter
doctorb's Avatar
While I'm at it syndrome:
doctorb is offline
post #49 of 53 (permalink) Old 08-19-2019, 06:32 PM
attempt at reply
Originally Posted by SkiBum View Post
I few have used my list. It is posted somewhere on a thread, for the life of me I cant remember what I named that thread... if I dont remember by tomorrow I will send you the list by PM.....
Is this the thread you are trying to remember SkiBum? "L-Jet Silicone hose kit"
https://www.alfabb.com/bb/forums/spi...-hose-kit.html
Lantheaume likes this.
1986 Red Alfa Spider Graduate
niebor is offline
post #50 of 53 (permalink) Old 08-22-2019, 12:40 PM Thread Starter
doctorb's Avatar
Before and after Cruzin Performance servicing. One thing's for sure: There's no way I'm letting that filthy tank load up these injectors.
New upper and lower seals, pintle caps, hose, and ferrules, to boot!
alfaromeoblack likes this.
doctorb is offline
post #51 of 53 (permalink) Old 08-22-2019, 01:06 PM
SkiBum's Avatar
just saw this post... I reposted the original post a week or 2 ago!
post #52 of 53 (permalink) Old 08-22-2019, 06:20 PM Thread Starter
doctorb's Avatar
Watching videos from when I got the car running, and considering the crap in the tank and the test data from Cruzin, I'm kind of amazed it actually ran. I'm really looking forward to refreshing the fuel system
doctorb is offline
post #53 of 53 (permalink) Old 08-29-2019, 03:07 PM Thread Starter
doctorb's Avatar
I started cleaning the inside of the tank. Once clean, I'll take care of the exterior.
My process, so far:
1. Dove and hose blast, twice to get rid of loose crap. Dump and dry.
2. 1 gallon vinegar and lots of swishing. I put a scotch brite pad on the end of a stick and spent a few hours scrubbing all areas I could reach. This scrubbing with the one gallon vinegar puddle was very effective, I thought. Not all areas could be reached, of course. Let vinegar sit for a day. Dump.
3. Then the big guns: Muriatic Acid approx 15% concentration, one gallon. Swish around. (Tip: I used rubber expandable plugs that are used to pressure test plumbing to minimize splashing. I left the small vapor and return barbs open to allow the whole tank to vent.) I let it sit for no more than an hour, turning and swishing every few minutes, until everything was squeaky clean.
4. Dump the acid in a bucket and funnel it back into a storage container for reuse.
5. Hose out the tank, dump the water in a bucket, neutralize the bucket water (not much baking soda was needed), and while the tank was still dripping wet inside, added half gallon of phosphoric acid. Let it sit for an hour, swishing occasionally.
6. Dump, dilute the remaining acid with water, add baking soda until fizzing stops. Swish and dump.
7. Hair dryer on high heat and air until bone dry, maybe an hour. (It was too hot to pick up with bare hands.)
There is some flash rust, and I'll probably do another round of phosphoric acid tomorrow. I'm happy with the results - a lot better than "as received".
radamm and Lantheaume like this.
doctorb is offline
