Transmissions question - Alfa Romeo Bulletin Board & Forums
post #1 of 9 (permalink) Old 07-19-2019, 11:36 AM Thread Starter
I couldn't quickly find the answer although I'm sure it's here somewhere.
I've got an 83 Spider.
Does a tranny from a 78 work in the 83 or are they completely different? I'm guessing they're not the same.
Lemme know!
jckevin is offline
post #2 of 9 (permalink) Old 07-20-2019, 06:53 AM
Richard Jemison
Alfar7's Avatar
Transmissions
They are the same. But putting in a trans that hasn`t been rebuilt is a mistake as in general there are two issues that need to be fixed. 1- the first gear syncro design. See the "Sticky" in the trans area. 2- 2nd gear syncros are the most problemsome and should be replaced.
Alfar7 is offline
post #3 of 9 (permalink) Old 07-20-2019, 08:20 AM Thread Starter
I wouldn't put the transmission in without doing those things first. Reverse is another common issue.
jckevin is offline
post #4 of 9 (permalink) Old 07-20-2019, 06:14 PM
ARwrench's Avatar
Location: Transplanted from Holland to The Armpit of New Jersey
...and after you rebuild the 78' you will have to use the 83' bellhousing.
“If you can't explain it simply, you don't understand it well enough”
Oo--V--oO There is a fine line between "Hobby" and "Mental Illness".
ARwrench is offline
post #5 of 9 (permalink) Old 07-20-2019, 06:32 PM
pantera928's Avatar
ARwrench beat me to it. 1978 did not have the sensors on the bell housing
pantera928 is offline
post #6 of 9 (permalink) Old 07-21-2019, 03:16 PM
I think one of the trannys need a belhousing that has holes cut into it for the shift forks to pass thru
bianchi2 is offline
post #7 of 9 (permalink) Old 07-21-2019, 06:47 PM Thread Starter
Thanks everyone. My bellhousing is fine to use. A lot of the parts in that 78 gear box, can possibly be used...plus other NEW parts. I've got doubts about my reverse gear, for example, and I am told those are really hard to find. For $100 i cannot go wrong if even a few parts in there are good.
jckevin is offline
post #8 of 9 (permalink) Old 07-21-2019, 09:29 PM
Jim G's Avatar
If the trans in your car doesn't pop out of reverse. Then is fine. Just reuse the 3 gears and the fork.
Jim G is offline
post #9 of 9 (permalink) Old 07-21-2019, 11:07 PM Thread Starter
It does pop out of R sometimes
jckevin is offline
