Ignition Advice - Page 2 - Alfa Romeo Bulletin Board & Forums
post #16 of 22 (permalink) Old 07-17-2019, 08:02 PM
GV27's Avatar
Yeah, just to back up SkiBum and reiterate my point from earlier: no points, no condenser - it's modern computerized ignition. Going to a Petronix unit would be a step backward and highly unlikely to improve anything.
Cap and rotor are a whopping $35.
Chris
1990 Spider Veloce
GV27 is offline
post #17 of 22 (permalink) Old 07-18-2019, 01:40 PM Thread Starter
Where is the fuel pressure regulator?
alfalori86 is offline
post #18 of 22 (permalink) Old 07-18-2019, 01:43 PM
SkiBum's Avatar
on the end of the fuel rail, above the distributor.
SkiBum is online now
post #19 of 22 (permalink) Old 07-19-2019, 12:28 AM
spiderserie4's Avatar
fuel pressure regulator is number 2 in diagram:
https://www.alfabb.com/bb/forums/8158178-post2.html
Top hose is vacuum hose from plenum (apart from checking this for raw fuel, also make sure the hose is not cracked)
Bottom hose is fuel return line.
spiderserie4 is online now
post #20 of 22 (permalink) Old 07-19-2019, 06:39 AM Thread Starter
Ok Updates! Found fuel regulator its brand new! Disconnected vacuum line and no raw gas. I started the car and got a spray bottle with water and sprayed what vacuum lines i could see no leaks. The car idles fine what I found was after driving it and stopping at a red light it got rough but not immediately at startup while standing.
post #21 of 22 (permalink) Old 07-19-2019, 06:44 AM
SkiBum's Avatar
Looking for a vacuum leak with water doesn't work, need some to be type a combustible liquid. Have you pulled your dipstick to look for an RPM change yet?
post #22 of 22 (permalink) Old 07-19-2019, 03:49 PM
so are you saying the 'rough running' really only occurs when the car warms up?
