-   Spider - 105 & 115 Series (1966-1994) (https://www.alfabb.com/bb/forums/spider-105-115-series-1966-1994/)
-   -   Ignition Advice (https://www.alfabb.com/bb/forums/spider-105-115-series-1966-1994/683136-ignition-advice.html)
GV27 07-17-2019 08:02 PM
Yeah, just to back up SkiBum and reiterate my point from earlier: no points, no condenser - it's modern computerized ignition. Going to a Petronix unit would be a step backward and highly unlikely to improve anything.
Cap and rotor are a whopping $35.
alfalori86 07-18-2019 01:40 PM
Where is the fuel pressure regulator?
SkiBum 07-18-2019 01:43 PM
on the end of the fuel rail, above the distributor.
spiderserie4 07-19-2019 12:28 AM
fuel pressure regulator is number 2 in diagram:
https://www.alfabb.com/bb/forums/8158178-post2.html
Top hose is vacuum hose from plenum (apart from checking this for raw fuel, also make sure the hose is not cracked)
Bottom hose is fuel return line.
alfalori86 07-19-2019 06:39 AM
Ok Updates! Found fuel regulator its brand new! Disconnected vacuum line and no raw gas. I started the car and got a spray bottle with water and sprayed what vacuum lines i could see no leaks. The car idles fine what I found was after driving it and stopping at a red light it got rough but not immediately at startup while standing.
SkiBum 07-19-2019 06:44 AM
Looking for a vacuum leak with water doesn't work, need some to be type a combustible liquid. Have you pulled your dipstick to look for an RPM change yet?
spiderserie4 07-19-2019 03:49 PM
so are you saying the 'rough running' really only occurs when the car warms up?
