91 S4 not starting, no gas - Alfa Romeo Bulletin Board & Forums
 1Likes
  • 1 Post By pinshaw
post #1 of 12 (permalink) Old 07-14-2019, 01:45 PM Thread Starter
pinshaw's Avatar
So I changed alternator , car started, dash lights out, changed fuse, got dash lights back. Decided to check fir other fuses n opened back panel w computer. Hit red button , now it won’t start. Thought it was just a test button, but now stuck. Tried a reset by disconnecting ground to battery. Relays click on power, power to coil,but no gas when turning over. Car was running fine before all this started. Wondering if I messed up crank sensor? Way to test? Ideas?
Peter Inshaw 59 Touring Spider 2.0, 63 Spider 1600, 67 GTV 1750, 67 Giulia Super Project, 73 Berlina TS, 91 Spider Veloce, 2018 Stelvio TI Sport
pinshaw is offline
post #2 of 12 (permalink) Old 07-14-2019, 02:37 PM
Gubi's Avatar
Check the relays in the back panel. One of them has a fuse right behind it that's for power to both fuel pumps and the oxygen sensor. It's possible that blew.
1974 GTV
1991 Spider
Former: 1987 Milano Gold
Gubi is offline
post #3 of 12 (permalink) Old 07-14-2019, 04:01 PM Thread Starter
pinshaw's Avatar
Thanks. I’ll check. I did check the 2 fuses on the relays as well as ohms to crank sensor. It checks out.
pinshaw is offline
post #4 of 12 (permalink) Old 07-15-2019, 02:40 AM
spiderserie4's Avatar
a clicking relay is not necessarily a working relay.
(Tom, the S4 fuel relay has no fuse...)
you have 4 relays back there:
the red stripe motronic diode relay-
the aux. motronic relay (this has the 15A fuse)-
the VVT relay (this has the 10A fuse)-
and the fuel/lambda relay (this has no fuse, no stripe, no nothing, so easily identifiable)
the pink/white wire from pin #87 of the fuel relay goes to the pumps.
remove the fuel relay and with an ohmmeter, test value between pins 85 & 86: you should see about 75-80 Ohms (if in doubt put the horn relay from the drop down fusebox in its place, they are the same)
Now pull the red stripe motronic relay, do the same test (as this is a diode relay, the black test lead needs to be on pin 85 and the red test lead on 86): you should get somewhere about 0.60 - 0.77 K/ohms
other than that I would put 12V direct to the fuel pumps and see that they are at least running when powered up (one in the trunk is easy to test as that is where your battery is!)
spiderserie4 is offline
post #5 of 12 (permalink) Old 07-15-2019, 07:08 AM Thread Starter
pinshaw's Avatar
Wow. Thank u. I’ll test those. Hope in changing battery, I didn’t stupidly knock something loose. Gotta be something basic. Car has been faultless up to this point.
pinshaw is offline
post #6 of 12 (permalink) Old 07-15-2019, 07:45 AM
Gubi's Avatar
If you trace the wiring, you'll see that the 15A fuse on the aux motronic relay also protects the fuel pump relay. Diagram I have is in German (which in this case probably works out pretty well.)
A failure mode I've seen on a couple of cars is that the lambda sensor heater shorts which blows this fuse, and then no power to fuel pumps.
1974 GTV
1991 Spider
Gubi is offline
post #7 of 12 (permalink) Old 07-15-2019, 07:57 AM
GV27's Avatar
If you don't find anything with the relays and/or fuses, you're correct that the crank sensor is the next thing to check. Test for resistance between the center pin and the outer pins. IIRC, one should be zero and the other 600ohm.
Chris
1990 Spider Veloce
GV27 is offline
post #8 of 12 (permalink) Old 07-15-2019, 09:19 AM Thread Starter
pinshaw's Avatar
Motronic relay/ red stripe reads zero 86 to 85. Tried reading s both red n blk leads on both ends. All others read 82 Assuming it’s unique given spec is different n red stripe. Lmk if there’s a sub to try otherwise I’ll order in a factory spec one. Thanks.
pinshaw is offline
post #9 of 12 (permalink) Old 07-15-2019, 11:21 AM
Originally Posted by pinshaw View Post
Motronic relay/ red stripe reads zero 86 to 85. Tried reading s both red n blk leads on both ends. All others read 82 Assuming itís unique given spec is different n red stripe. Lmk if thereís a sub to try otherwise Iíll order in a factory spec one. Thanks.
sounds bad, so time to replace it.
When you order, order two of them!
All S4 drivers should have a spare in the glove box!
Original is Bosch 0 332 014 112
same as Range Rover Classic V8 Efi /Discovery1 V8 Efi (part: LR - AFU2913L)
about 15 bucks on ebay.
post #10 of 12 (permalink) Old 07-19-2019, 07:15 PM Thread Starter
pinshaw's Avatar
Solved
FWIW ignition relay doesn’t have an ohm reading since I gather it’s open until started. Swapped in the one from the TS for testing.
It had same reading n ran fine. Spider one did as well
What finally was the issue was the wire connector was pushed down in the plastic housing, so not seating w the relay.
Stupidly simple. Car all good now.
Thanks for the learning experience.
integrale likes this.
pinshaw is offline
post #11 of 12 (permalink) Old 07-20-2019, 07:43 AM
Solved
It had same reading n ran fine. Spider one did as well...
glad it is solved
however I do not follow you on "no" ohms reading thing.....
It will read
a) if you chose the correct pin #s, which I am sure you did.
b) if you switch the DVM to the correct register, in the case of my DVM below, it needs to be in the 2000 range....if you leave it in the 200 range you just get a bar (---)
all 3 of my spare red stripes read out:
post #12 of 12 (permalink) Old 07-20-2019, 07:58 AM Thread Starter
pinshaw's Avatar
Good to know.
I’ll try it. I did have it on 200
others read 82, new back ups at 91
pinshaw is offline
