Flywheel positioning - Alfa Romeo Bulletin Board & Forums
 1Likes
  • 1 Post By Jim G
post #1 of 5 (permalink) Old 07-10-2019, 12:17 PM Thread Starter
scagliog's Avatar
Hello,
got a transmission rebuilt, new clutch and resurfaced flywheel.
Putting all back together... can anybody confirm that with the crank pully alligned on the "P" punto mark, and the flywheel notch at 12 o'clock it is OK to have the magnetic sensor screw about 2 inches from the first sensor hole between the 2 studs?
Thanks!
Giuseppe
"alfista"
scagliog is offline
post #2 of 5 (permalink) Old 07-10-2019, 12:38 PM
sloboy89's Avatar
I'm assuming that this is on your 82 Spider with the stock Bosch L-Jet. In the photo below, you can see the flywheel mark at 12 o'clock and the location of the sensor screw on my S3.
Rich
'85 Spider Veloce
'17 Giulia Ti Sport
sloboy89 is online now
post #3 of 5 (permalink) Old 07-10-2019, 01:16 PM Thread Starter
scagliog's Avatar
Yes!! 82 Bosch..looks like yours thank you
Giuseppe
"alfista"
scagliog is offline
post #4 of 5 (permalink) Old 07-11-2019, 03:00 PM
Jim G's Avatar
You will find a stamped line on the outside rim of your flywheel. This is the top dead center mark. You will also find that in one of the flywheel bolt holes the threads are recessed. This is the top dead center of the engine. Line the mark on the outside rim of the flywheel to the hole with the recessed threads and your flywheel will be in phase with the crank.
Using this method you don't have to line up the pulley with the pointer.
radamm likes this.
Jim G is offline
post #5 of 5 (permalink) Old 07-12-2019, 12:28 AM
spiderserie4's Avatar
this shows both the alignment mark and the recessed threads, which Jim G refers to:
https://www.alfabb.com/bb/forums/6824673-post16.html
spiderserie4 is offline
