Starter Relay - Alfa Romeo Bulletin Board & Forums
 1Likes
  • 1 Post By fransinge
post #1 of 8 (permalink) Old 07-01-2019, 04:47 PM Thread Starter
Jack Straw's Avatar
Starter Relay
I want to put a starter relay in my S4 but before I dig into it I'm wondering if the starter trigger wire and main lead to the battery are better accessed from above or below? It appears that to get to them from above the plenum will have to come off so it it's simpler to come from below I'll just bribe slow creek to put it up on his lift.
Somebody must have done this on an S4.
Bill
1991 S4 Spider "Gabriela", 2017 VW Golf R, 2018 VW GTI,
Previous obsessions; 2006 Mustang GT, 2006 BMW Z4M, 5 other Bimmers, Capri V6, Renault 5, Lotus Cortina, Sunbeam Alpine, Ducati Diana Mk 3, Norton Commando
Jack Straw is offline
post #2 of 8 (permalink) Old 07-01-2019, 04:50 PM
Gubi's Avatar
You can do it all from above without removing the plenum. It's tight but I don't remember it being crazy hard to get to the connections at the starter.
Obviously, make sure you disconnect the battery before doing anything.
1974 GTV
1991 Spider
Former: 1987 Milano Gold
Gubi is offline
post #3 of 8 (permalink) Old 07-01-2019, 04:59 PM Thread Starter
Jack Straw's Avatar
Thanks for the speedy reply. I'm usually pretty good at getting at "impossible" fittings but I honestly don't know how to reach the starter connections from above. Reaching under the plenum seems too tight to manipulate any kind of tool. Straight down through the plenum I can see the terminals but I can't figure a way to get a tool on 'em.
I'll keep staring at it for a while and maybe it'll shape shift.
Bill
post #4 of 8 (permalink) Old 07-01-2019, 05:57 PM
sloboy89's Avatar
You can get at it by reaching under plenum from the front. Probably need to work by feel, but it's not that difficult.
Rich
'85 Spider Veloce
'17 Giulia Ti Sport
sloboy89 is offline
post #5 of 8 (permalink) Old 07-01-2019, 05:58 PM
Gubi's Avatar
The solenoid is just a spade terminal you can reach in and pull off. The big nut on the starter is where you want to pull power from, I think I just used a bunch of extensions under the plenum to get it off and then added a ring terminal. Helps to have small hands.
1974 GTV
1991 Spider
Gubi is offline
post #6 of 8 (permalink) Old 07-01-2019, 06:08 PM
BB Janitor
ghnl's Avatar
Be sure to disconnect the battery first (unless you like big sparks...).
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
ghnl is offline
post #7 of 8 (permalink) Old 07-01-2019, 06:48 PM Thread Starter
Jack Straw's Avatar
Thanks gentlemen. I'll git 'er done. I had not tried access from the front of the plenum.
Bill
post #8 of 8 (permalink) Old 07-02-2019, 12:21 PM
fransinge's Avatar
Hi, I assume you want to place a relay to save your ignitionswitch ?
I've placed a relay on a spare spot on the fusebox, no heat or weatherconditons there to cause mallfunction of the relay, just my 2 cents
greetz,
Frans
factotum likes this.
'86 Quad Spider
fransinge is offline
