Sealants: Rear Axle Seal Install & Axle Tube - Alfa Romeo Bulletin Board & Forums
post #1 of 13 (permalink) Old 06-18-2019, 12:07 AM Thread Starter
crackie's Avatar
Have spent about an hour reading various posts, manuals, etc. on installing the rear axle seal in the axle tube per picture below (not mine, just grabbed off BB).
Seems some people use Permatex Ultra Blue between the outer seal housing and the axle tube to make sure it doesn't leak there. Some use grease there. Seems some don't use anything. I was thinking of using some Permatex Anaerobic (51813). What's the best practice here?
Also, I assume Permatex Anaerobic gets used where the axle tubes mate with the differential pumpkin, correct? Manuals don't mention it, but I see it some posts.
Thanks!
--Scott
Current: 85 GTV6, 69 Duetto, 17 Giulia, 74 GTV
Past: 65 Giulia Sprint GT, 77 Alfetta, 79 Alfetta, 87 Milano Gold, 74 GTV (Euro)
crackie is online now
post #2 of 13 (permalink) Old 06-18-2019, 12:09 AM
PSk
Alfa didn't use anything ...
'71 1750 Series 2 GTV:
PSk is offline
post #3 of 13 (permalink) Old 06-18-2019, 10:04 AM Thread Starter
crackie's Avatar
Thanks for that.
Yeah - sometimes hard to tell given how the manuals are written (guessing translation from Italian). Here's the 89 Spider page where, I **think** it is trying to say that they recommend moly grease on the outside metal housing of the seal. But hard to tell from how written. Sheesh.
--Scott
post #4 of 13 (permalink) Old 06-18-2019, 10:15 AM
I just put a thin film of Permatex Ultra Black on and tapped the seal into place only because I scratched the mating surface a tad getting the old seal out. Can't see a reason not to even though i'm sure someone will say otherwise.
stradguy93 is offline
post #5 of 13 (permalink) Old 06-18-2019, 11:55 AM Thread Starter
crackie's Avatar
Also - can someone confirm that I should be using Permatex on the axle tube-to-differential pumpkin mating surfaces?
Again there nothing in the manuals, but seems like it would be assembled like a gearbox case which does require it.
Thanks!
--Scott
post #6 of 13 (permalink) Old 06-18-2019, 02:19 PM
PSk
Originally Posted by crackie View Post
Thanks for that.
I stand corrected.
PSk is offline
post #7 of 13 (permalink) Old 06-18-2019, 05:39 PM Thread Starter
crackie's Avatar
Yeah, maybe. I’m not even 100% sure that’s what it’s saying given the complicated verbiage.
At any rate, can anyone confirm my 2nd question on using a sealant between axle tube ends and the differential? Seems like the right thing to do.
Thanks.
--Scott
post #8 of 13 (permalink) Old 06-18-2019, 07:05 PM
PSk
Thanks.
I did when I rebuilt my axle.
PSk is offline
post #9 of 13 (permalink) Old 06-18-2019, 07:16 PM
goats's Avatar
Anaerobic sealer on the diff car halves and pass side axle tube
goats is online now
post #10 of 13 (permalink) Old 06-18-2019, 08:05 PM Thread Starter
crackie's Avatar
Thanks guys!
--Scott
post #11 of 13 (permalink) Old 06-18-2019, 08:12 PM
goats's Avatar
Torque to spec ; section 17 , 19.5 ft/lbs as I recall
goats is online now
post #12 of 13 (permalink) Old 06-20-2019, 04:46 PM
The seal ring should be packed with grease, which helps ensure that its gaiter is not disturbed during installation. The gaiter is that spring inside the seal's lip. I smear a little of that same grease on the outside of the seal to ease its installation and reduce the chance of tearing or scuffing the rubber surface.
If there's a lot of corrosion of the metal where the seal sits, a sealant such as type 574 may be helpful instead of smearing the grease.
If you have a LSD, be sure the grease does not contain MoS2 (moly disulfide), which will poison the clutch plates. I use an Audi product, p/n G.052.128.A1, which is really handy for smaller diameter radial oil seals because it's in a tube with a nozzle and is easy to squirt into the seal. But any grease without MoS2 should be just fine. Cheers,
Kevin
Catellus Engineering, Inc. - http://catellusengineering.com/
CatellusEng is offline
post #13 of 13 (permalink) Old 06-20-2019, 05:39 PM Thread Starter
crackie's Avatar
Ah - you know, I didn't even think about that. That is a good call out.
--Scott
