Rear Axle Seal Removal - I must be doing it wrong... - Alfa Romeo Bulletin Board & Forums
 3Likes
post #1 of 16 (permalink) Old 06-15-2019, 12:33 AM Thread Starter
crackie's Avatar
Per pictures below, I cannot get the rear axle seal out of the axle tube. Tube is separated from the pumpkin, which doesn't help with leverage or tapping the seal removal tool, but I must be doing something wrong as it hasn't moved a bit.
I am worried if I keep going I will completely bend the metal lip of the seal and never get it out.
Any suggestions?
Already PB blasted for a couple days and am working my way around the seal with a removal tool, but no dice.
--Scott
Current: 85 GTV6, 69 Duetto, 17 Giulia, 74 GTV
Past: 65 Giulia Sprint GT, 77 Alfetta, 79 Alfetta, 87 Milano Gold, 74 GTV (Euro)
crackie is offline
post #2 of 16 (permalink) Old 06-15-2019, 07:20 AM
Gubi's Avatar
Maybe someone glued it in with silicone? Time to try a torch, I think.
Mine didn’t come out easy but I had nowhere near that much trouble, so that isn’t normal.
1974 GTV
1991 Spider
Former: 1987 Milano Gold
Gubi is offline
post #3 of 16 (permalink) Old 06-15-2019, 10:17 AM Thread Starter
crackie's Avatar
Yeah that was one of my questions - is there anything to hurt in there if I put a torch on it. Sounds like not, so I will give that a try.
--Scott
crackie is offline
post #4 of 16 (permalink) Old 06-15-2019, 11:45 AM
Gubi's Avatar
I don't *think* so. The tube is steel. The only temperature-sensitive thing I can think of there is the rubber in the seal itself, and obviously you don't care about that.
1974 GTV
1991 Spider
Gubi is offline
post #5 of 16 (permalink) Old 06-15-2019, 12:18 PM Thread Starter
crackie's Avatar
Seems like there shouldn't be a problem. Also thinking about trying to get a small 2-arm puller in there too with a piece of steel across the top to push against. That's the extent of my ideas for the moment.
--Scott
crackie is offline
post #6 of 16 (permalink) Old 06-15-2019, 02:12 PM
Jim G's Avatar
A hammer and several center punches and you will be able to bend the ring in enough that it will pop out.
Jim G is offline
post #7 of 16 (permalink) Old 06-15-2019, 02:30 PM Thread Starter
crackie's Avatar
That's a good idea. I thought about trying to cut it to the edge like with a stuck bushing casing, but was a bit worried about nicking the axle tube because of the weird angle. Hammer and punch a much better idea.
Thanks!
--Scott
crackie is offline
post #8 of 16 (permalink) Old 06-15-2019, 06:18 PM
radamm's Avatar
Silicone will cover any small knicks within reason anyway.
__________
Rick
MEMBRO LATO OSCURO
69 850 Spider (A fond college days' memory)
81 Spider Veloce
Downstate Illinois SNO Director
radamm is offline
post #9 of 16 (permalink) Old 06-15-2019, 06:23 PM
PSk
Sometimes we get a bit scared working on our "special" Alfas.
A mechanic would have grabbed a big hammer and punch, etc. and swung away and sorted it in seconds.
The bigger the hammer the less damage is done! (i.e. 1 big hit is better than hundreds of little nervous hits)
'71 1750 Series 2 GTV:
PSk is offline
post #10 of 16 (permalink) Old 06-15-2019, 07:11 PM
Jim G's Avatar
Yep. Because thats what I do as a mechanic.
Jim G is offline
post #11 of 16 (permalink) Old 06-15-2019, 09:40 PM
I use a long metal rod inserted from the pumpkin end and angled so to pick up the lip of the seal. A couple of good wacks with a hammer and it should pop out.
https://youtu.be/1n6QhxZ16XI
spiderserie4 likes this.
gprocket is offline
post #12 of 16 (permalink) Old 06-15-2019, 09:59 PM Thread Starter
crackie's Avatar
@gprocket - that was where I first started actually. No luck. The protrusion inside the axle tube right before the seal makes it hard to get the ram rod good and flush on the seal. As a result the metal edges of the seal just bend...at least for me. This axle sat in a field for along time, so guessing there's a fair amount of corrosion and/or loctite under it.
--Scott
crackie is offline
post #13 of 16 (permalink) Old 06-15-2019, 11:33 PM Thread Starter
crackie's Avatar
Center punch, cold chisel, suitable pry bar & a BFH solve the problem in about 2 mins just as JimG and PSk said. And I learned something knew in the process. Much thanks guys!
Jim G and alfaromeoblack like this.
--Scott
crackie is offline
post #14 of 16 (permalink) Old 06-15-2019, 11:46 PM Thread Starter
crackie's Avatar
And the one from the second axle tube came out with about 4 hits of the seal removal tool (in my case, my narrow pry bar). Guess it was payback for the difficulty on the other side.
Thanks for the help everyone!
--Scott
crackie is offline
post #15 of 16 (permalink) Old 06-20-2019, 04:50 PM
I've occasionally used an internal puller (Kukko) on some such seals. The rubber gets well and truly bonded to the mating surface with heat and age. I'll use JB Weld to fill gouges introduced into the sealing surface: smear it in a little higher than the surface, let it harden and shrink, then use fine sandpaper or a razor blade to get the surface right. Cheers,
Kevin
Catellus Engineering, Inc. - http://catellusengineering.com/
CatellusEng is offline
