Best alignment numbers - Alfa Romeo Bulletin Board & Forums
post #1 of 6 (permalink) Old 06-13-2019, 11:02 AM Thread Starter
SkiBum's Avatar
After installing my chassis stiffener my alignment changed. This is for the steering geometry gurus....
Anybody have any input on the best toe/caster/camber numbers?
SkiBum is online now
post #2 of 6 (permalink) Old 06-13-2019, 05:31 PM
lgbalfa's Avatar
Send a message via Skype™ to lgbalfa
Do a search on the forum.
I think this has been covered in the past.
1992 Alfa Romeo Spider Veloce, 2017 Alfa Romeo Giulia, 2018 Volkswagen Tiguan SEL Premium
lgbalfa is offline
post #3 of 6 (permalink) Old 06-13-2019, 06:13 PM
BB Janitor
ghnl's Avatar
From the Spider Shop Manual:
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
ghnl is online now
post #4 of 6 (permalink) Old 06-13-2019, 06:22 PM Thread Starter
SkiBum's Avatar
Thanks for the reply.
I have a CarDisc and looked over the factory specs, I just thought maybe someone had possibly played with different numbers and came up with a setup that may be an improvement, but maybe Alfa had it dialed all along....who can mess with perfection? Thanks again for the input. Off to the alignment shop tomorrow with factory settings, in case they don't have them....
post #5 of 6 (permalink) Old 06-13-2019, 07:58 PM
Supporting Vendor
JoeCab's Avatar
We've found that, depending on your tire size and/or driving style, you may want more negative camber and more castor than the factory settings. Of course the ability to dial in more negative camber depends on having adjustable upper control arms in place, which a large majority of 105/115 cars do at this point.
Here's a chart with both factory and modified suspension settings:
https://centerlinealfa.com/sites/cen...otor_specs.pdf
Centerline International - Alfa Romeo Parts & Accessories
750-ALFA
JoeCab is offline
post #6 of 6 (permalink) Old 06-13-2019, 08:41 PM Thread Starter
SkiBum's Avatar
Awesome! I will have to check those out, thanks!
