Transmission drain plug - Alfa Romeo Bulletin Board & Forums
post #1 of 13 (permalink) Old 06-05-2019, 04:12 PM Thread Starter
kentjw's Avatar
1988 Spider Quad
So, I mangled the tranny drain plug trying to get it out. Finally got it with an extractor socket and ground it down so I could use a 3/4 wrench to put it back in. Now, it drips a little everyday and I'd like to replace but can't find anywhere. No, I did not put a new washer on. Can't even find what size it is.
Not sure why these are made of soft brass. Probably something to do with the magnet. I'm not a metallurgist, but I was wondering if brass and aluminum expand and contract at the same rate. I say this because it only leaks after a drive.
Anyway, I'd like to get a new plug if anyone knows who has these or at least knows the thread size.
Alternative is try to get old one out again and use a new washer but afraid I'll end up plug less.
KJW
kentjw is offline
post #2 of 13 (permalink) Old 06-05-2019, 04:32 PM
Lokki's Avatar
Lokki is offline
post #3 of 13 (permalink) Old 06-05-2019, 04:43 PM Thread Starter
kentjw's Avatar
The link is for the differential. Think there the same?
KJW
kentjw is offline
post #4 of 13 (permalink) Old 06-05-2019, 05:07 PM Thread Starter
kentjw's Avatar
Just got an email from Jon at Alfa Parts in Berkeley, Ca. He has in stock. $22.+
KJW
kentjw is offline
post #5 of 13 (permalink) Old 06-05-2019, 06:03 PM
Gordon Raymond's Avatar
The brass will not gall in the aluminum, and when overtightened, it does what yours did rather than strip out the aluminum threads. Some later ones were steel. Not as user friendly as brass.
Gordon Raymond
Now:
Gordon Raymond is offline
post #6 of 13 (permalink) Old 06-06-2019, 04:34 AM Thread Starter
kentjw's Avatar
Makes sense. I learned something today. Thanks Gordon.
KJW
kentjw is offline
post #7 of 13 (permalink) Old 06-06-2019, 06:21 AM
GV27's Avatar
They are the same.
Chris
1990 Spider Veloce
GV27 is offline
post #8 of 13 (permalink) Old 06-06-2019, 08:07 AM
spiderserie4's Avatar
when you order a new one ask for a new copper washer too...it won't come with it.
odd the OKP link says it fits the top of the cylinder head too..........not sure you really need a magnet there!
spiderserie4 is offline
post #9 of 13 (permalink) Old 06-06-2019, 08:46 AM Thread Starter
kentjw's Avatar
New washer for sure! I guess they're referring to the freeze plugs...agree, strange place for a magnetic plug.
KJW
kentjw is offline
post #10 of 13 (permalink) Old 06-07-2019, 07:56 AM
GV27's Avatar
I imagine that it just happens to be what they have with the right threads and length. My parts manual shows a common part number for the drain plugs (60703262) but a different number for the head plug as you would expect.
Chris
1990 Spider Veloce
GV27 is offline
post #11 of 13 (permalink) Old 06-07-2019, 05:39 PM Thread Starter
kentjw's Avatar
Alfa Parts thought they had tranny drain plugs but, no. Does anyone know if the oil sump plug is the same size? This is frustrating not being able to find any info on this part.
KJW
kentjw is offline
post #12 of 13 (permalink) Old 06-09-2019, 04:28 PM
Yachtman's Avatar
Centerline has them I think.
Part # OP622B
https://centerlinealfa.com/sites/cen...xle/op622b.jpg
[B][I][U]Current[/U][/I][/B]
1984 Spider Veloce Deluxe
1969 GT 1300 JR
1969 1750 Spica Spider Veloce
1963 MGB
1952 MG TD
Others??!!!😃😃
Yachtman is offline
post #13 of 13 (permalink) Old 06-09-2019, 05:29 PM Thread Starter
kentjw's Avatar
Thanks Yachtman but that's not it...might fit though. Anyway, it's fixed. I drained out the Redline into a clean container so I could reuse ($$). Then I found a 22mm new copper washer at local hardware store. I filed the bolt down so a 19mm wrench would fit then put a thin coat of gasket goo on and snugged it down but not to tight. No more leaks!
So, that's it until the next issue pops up which I think is going to be new exhaust gaskets as I'm getting that ticking sound at hot idle. Been there and done that with my '74.
Thanks again.
KJW
kentjw is offline
