Ticking noise coming from middle / rear of engine - Alfa Romeo Bulletin Board & Forums
 1Likes
  • 1 Post By ghnl
post #1 of 14 (permalink) Old 06-04-2019, 06:38 AM Thread Starter
Question Ticking noise coming from middle / rear of engine
New to me 1750 spica '71 spider is making a ticking noise mostly at idle and maybe till about 2k but as the revs climb I don't hear it. I though it was an exhaust leak but I can't feel any air around the manifold or at the collector and don't see any soot. The car only has about 38k miles on it, not sure if this is enough mileage to consider needing to re-shim the valves but I have not measured clearances yet.
I read that if it was an exhaust leak it should get louder & persist as revs climb. The car drives fine otherwise and I know that spica being mechanical injection should be somewhat loud (i daily a 97 tdi so I know what mech injection sounds like) when firing the injectors but this noise is from the drivers side roughly middle or rear (towards firewall) of the engine.
Quick list of maintenance I did last fall:
fuel filter (at spica and inline at tank)
oil filter (engine and spica filter)
oil pressure sender(gauge tested fine)
airbox filters
diff oil
trans oil
engine oil 20w50
Here is a short video I took.
drive.google.com
/file/d/1iuY37qQG4fqn98TQLy8fQn-AeXVxGVbx/view?usp=drivesdk
AlexBassila is offline
post #2 of 14 (permalink) Old 06-04-2019, 07:09 AM
BB Janitor
ghnl's Avatar
My first thought was an exhaust leak, too. One way to locate it is to use a 2' - 3' length of 1/2" hose (like a piece of heater hose) as a stethoscope. It won't amplify the sound but you can safely aim one end at any suspect areas and listen at the other end.
It would certainly be a good time to check valve clearances.
sbadaro likes this.
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
ghnl is offline
post #3 of 14 (permalink) Old 06-04-2019, 07:50 AM
spiderserie4's Avatar
sounds typical alfa twin cam to me
exhaust #3 looks to be double nutted, if so why, a quik fix for a possible stripped stud perhaps?
In any case, certainly no harm in snugging up all those nuts.
have you adjusted the chain recently?
no harm also to at least check the valve gaps, as Eric says
(removing cam cover on your car is nice and easy compared to later spiders!)
spiderserie4 is online now
post #4 of 14 (permalink) Old 06-04-2019, 08:14 AM
goats's Avatar
sounds like exhaust to me as well. That 1750 should not be making that much noise at idle.
goats is offline
post #5 of 14 (permalink) Old 06-04-2019, 08:23 AM Thread Starter
#3 is double nutted as a test a few min before taking that video. The stud looked a little chewed up right where the manifold meets it and the nut also loos a little chewed so I put another nut as a "spacer" to try and tighten the nut on some fresher threads. All other nuts are verified tight and sound didn't change when trying my nut spacer. I guess its still possible for #3 being a source of exhaust leak but I don't feel any air and the ticking essentially disappears somewhere above 2k (I stood half out of the car to rev while listening to the engine with hood up).
post #6 of 14 (permalink) Old 06-04-2019, 08:48 AM
Ha, I have the exact same noise at #3 or #4 exhaust side! It started after an oil change and noticed after running the living daylights out of the car - which she normally enjoys.
Adjusted the timing chain as it seemed loose, measured the valve clearances and used a stethoscope to find if the noise was louder around the engine. Definitely coming from the exhaust side around #3 and #4, I think #4.
I did not check to see if the exhaust nuts were tight and will do so this weekend.
The clearances are as follows:
IN EX
1. .011" .014"
2. .012" .015'
3. .012" .014"
4. .012" .012"
I am not sure of the cams as I believe they are regrounds however RJ did provide valve clearances to use.
My old post is here: https://www.alfabb.com/bb/forums/eng...00-duetto.html
Plus I to have uploaded a short video of the engine noise and it is below.
https://drive.google.com/open?id=1Va...FhrSOTFqNiO9qS
Thoughts appreciated.
Chip
post #7 of 14 (permalink) Old 06-04-2019, 10:48 AM
ah ok, thanks, that explains that!
if nuts are all snug and no signs of carbon escape, then I'd say the flange is good.
what about the manifold itself, no slight crack a little lower down?
(though your 71 will have the good 2 piece manifold, less prone to cracking than the later USA one piece restrictive piece)
I'd still adjust timing chain, if you haven't done it on this new to you spider.
Our twin cams seem to transmit noise and it's hard to pin point the source. A loose chain can be noisy.
....maybe check the compression in cylinders to rule out anything odd there that might have happened after your italian tune up: all plugs out, hot engine, wide open throttle.
(edit) oh, sorry, it wasn't you who did this, it was shuga....got myself mixed up!
post #8 of 14 (permalink) Old 06-04-2019, 11:59 AM
Top Down's Avatar
I had an odd ticking (sort of) sound which took ages to locate, that turned out to be an air leak on cylinder #4 between manifold and head.
Daily drive is a Giulia 2.0 MA, wife drives a 939 Spider in the summer and a 1.6TS 147 in the winter. For special sunny days we have a S2 Spider Junior in the garage.
Top Down is offline
post #9 of 14 (permalink) Old 06-04-2019, 01:39 PM
VabeneGTV's Avatar
loose plug(s)
Cars ruined my life! 😱
VabeneGTV is online now
post #10 of 14 (permalink) Old 06-05-2019, 09:49 AM Thread Starter
Haven't checked for loose plugs yet but I will inspect that next as well as get the car up on stands and check the collector underneath for leaks as I am also hearing the same ticking noise under the car around the collector / front muffler section (its less pronounced but the sound is also present under the front of the car).
Something else I observed is that the ticking is approximately the same frequency as the bouncing of the tachometer at idle. Is it possible for the tach cable to make such a noise? I read another post where someone talked about the tach cable making noise when its needing to be lubricated.
Thanks for the input guys, I am hoping its just exhaust related, although the engine has low mileage I know the previous owner hardly did any maintenance (same air filter and pcv breather for the last 10+ years and spica filter was super slugged up), so it's not hard to imaging he might have not checked oil level or used incorrect oil etc.
post #11 of 14 (permalink) Old 06-06-2019, 07:44 PM
I can’t open your video, so I will just ask. Is this a California car and if so, are you still running the air pump? The air exhaust rails are fragile and can spring leaks. Makes a loud ticking noise. Happened to me. You can replace the air rail or mend it with high temp epoxy
Mauricio101 is offline
post #12 of 14 (permalink) Old 06-06-2019, 08:04 PM
goats's Avatar
No air pump on 71
goats is offline
post #13 of 14 (permalink) Old 06-10-2019, 11:04 AM Thread Starter
Originally Posted by Mauricio101 View Post
I canít open your video, so I will just ask. Is this a California car and if so, are you still running the air pump? The air exhaust rails are fragile and can spring leaks. Makes a loud ticking noise. Happened to me. You can replace the air rail or mend it with high temp epoxy
Not a cali car. Tach needle is bouncing at about the same speed / rate as the ticking noise. I checked spark plugs and they are all tight. The ticking noise doesn't get louder only faster as rpms increase. I read another post about tach cable making this type of noise, I'm not sure though as the cable runs to the water pump which is usually at the front of the engine.
I guess my next step is to pull the manifold and replace the 1 chewed up stud and replace the gaskets to see if that is the issue. I will also replace the collector gaskets at the same time.
post #14 of 14 (permalink) Old 06-10-2019, 11:29 AM
PSk
Does the tach cable require lubricating?
'71 1750 Series 2 GTV:
PSk is online now
