Spica Blanking Plate - Alfa Romeo Bulletin Board & Forums
post #1 of 11 (permalink) Old 05-20-2019, 02:39 PM Thread Starter
Crowbar44's Avatar
Hello Gents,
I have a Weber Converted '81 Spider. Can someone please post a picture or diagram of where on the engine block the blanking plate for the SPICA's sit. I'm trying to fettle an oil leak and suspect this may be the culprit.
GC
'81 Spider (Weber's, Euro Bumpers, Custom Interior) Ivorio over Red | '54 Austin Healey 100-4, Bone Stock save for M cam, Carmine over Black.
Crowbar44 is offline
post #2 of 11 (permalink) Old 05-20-2019, 03:19 PM Thread Starter
Crowbar44's Avatar
Is the red arrow pointing to the plate?
post #3 of 11 (permalink) Old 05-20-2019, 03:27 PM
VabeneGTV's Avatar
Yes it is, definitely pointing at it, sorry couldn’t help myself!
Cars ruined my life! 😱
VabeneGTV is online now
post #4 of 11 (permalink) Old 05-21-2019, 06:28 AM
I'm curious about the goal of all the stuff where the oil pressure sender normally goes?
Cheers,
Carson, 4 Alfa's, 9 Cars, 4 Motorcycles
vintagemilano is offline
post #5 of 11 (permalink) Old 05-21-2019, 07:01 AM
Alfajay's Avatar
As I recall, there is a square-section "O" ring between the timing chain cover and the Spica pump that seals the oil supply to the pump. You need to have that "O" ring installed when the block-off plate is used. So perhaps that part is missing, causing the oil leak.
I assume the add-on plumbing supports a sender for an auxilliary gauge. But I'm concerned that the unsupported pipe & fittings are prone to fatigue from vibration. A failure there would result in a rapid loss of oil.
'63 Guilia spider
Alfajay is offline
post #6 of 11 (permalink) Old 05-21-2019, 09:33 AM Thread Starter
Crowbar44's Avatar
SPICA Blanking plate
So all kidding aside - is this the blanking plate for the SPICA? My car still has some equipment bolted to this region, I suspect it is some vestige of the SPICA...and I'm pretty sure it's leaking oil.
FYI the pictures above is not of my car....just something I grabbed off the web
post #7 of 11 (permalink) Old 05-21-2019, 10:02 AM
Alfajay's Avatar
Yes, the red arrow in that photo points to the Spica block-off plate. That car has no Spica gear left, but I can't comment on your's. But other than the block-off plate, I can't imagine what other Spica-related stuff could cause an leak oil.
OK, you're excused for the klugey pipe & sending unit shown in the photo.
'63 Guilia spider
Alfajay is offline
post #8 of 11 (permalink) Old 05-22-2019, 06:44 AM Thread Starter
Crowbar44's Avatar
So this is what's sitting in my car at the location the blanking plate should be... I'm assuming it's some residuum of the SPICAs. I'm planning to remove it and install a proper blanking plate
post #9 of 11 (permalink) Old 05-22-2019, 06:47 AM
Alfajay's Avatar
Yes, you're right. Looks like a PO left the lower part of the Spica pump in place, and then bolted a homemade block-off plate to the top of that. Don't know why that set-up would leak, but using a purpose-built block-off plate would certainly be neater.
'63 Guilia spider
Alfajay is offline
post #10 of 11 (permalink) Old 05-22-2019, 07:54 AM Thread Starter
Crowbar44's Avatar
Thanks Jay,
A question to all on the blanking plate - does it need a gasket or is Permatex enough for a seal? No-one who sells the blanking plate sells an accompaying gasket... I could always make one out of gasket material...
post #11 of 11 (permalink) Old 05-22-2019, 08:06 AM
Alfajay's Avatar
That would be your best bet. You don't even need to cut out the inside - just trace the outside of the plate, put 4 holes in it, and you're done. Hmm - in thinking some more, the gasket may need a 5th hole, near the center, where the O ring seats.
If your goal is to stop oil leaks, I wouldn't try the short cut of skipping the gasket and just using sealant.
'63 Guilia spider
Alfajay is offline
Similar Threads
SPICA Belt Replacement and Timing ihart Carburetors, Fuel Injection & Air Intake 3 06-07-2017 05:12 AM
bluetooth module for behind blanking plate ambush276 Spider - 105 & 115 Series (1966-1994) 26 10-20-2016 03:55 PM
For Sale: Spica Fuel Injection Block Off Plate Delllta Alfa Romeo Parts For Sale & Wanted 0 10-19-2013 05:37 PM
Installing a renovated SPICA (for first timers) cabikefreak Carburetors, Fuel Injection & Air Intake 4 11-19-2009 08:30 PM
