Towed last week towed today S3 - Alfa Romeo Bulletin Board & Forums
post #1 of 10 (permalink) Old 05-16-2019, 12:18 PM Thread Starter
Towed last week checked spark OK But no fuel .Pump fuse bad replaced and started.Next I find fuel pump running with key in off,bang pump relay and it stops.Order new relay.Clean all grounds. Install new relay .Car starts but runs very bad till it warms up. GO for a drive 20 minutes later dead on the side of the road. Check spark OK.Check fuse OK.check power to fuel pump none.Hot wire fuel pump .Still no start . Towed in .I'm not in a good mood today .Tomorrow I will start to look some more .Any ideas?
dolmon is offline
post #2 of 10 (permalink) Old 05-16-2019, 12:25 PM
horsewidower's Avatar
Your pump may be dying. I had an intermittent problem about a month ago. It would work fine when tested statically, or just after starting. However, after it had run for 10-20 minutes the pump would seize. Once it cooled off, I could get it to run, again, for a short amount of time.
But wait there's more: View my 164LS thread:
You didn't...oh yes I did II. 1995 164LS 5 speed, awesome when it runs!!!
Musings on shop related items:
horsewidower is offline
post #3 of 10 (permalink) Old 05-16-2019, 12:28 PM Thread Starter
I checked the pump when hot wired it was running ok but tomorrow I will check the flow.
dolmon is offline
post #4 of 10 (permalink) Old 05-16-2019, 12:32 PM Thread Starter
Good fuse new relay no voltage to pump.With pump running no start.
dolmon is offline
post #5 of 10 (permalink) Old 05-17-2019, 12:43 AM
spiderserie4's Avatar
when you jump the big Drive/Fuel relay socket (between #30 & #87) both pumps run, correct? - if not, then suspect wiring or connectors G73 or G107, or that troublesome bullet fuse holder (fuse blew for a reason!)
if yes, then suspect the new relay gone bad - was it a cheap(er) KAE or a proper Bosch relay you replaced it with?
I'd double check spark again, just to exclude that hasn't coincidentally gone awol.
perhaps smaller (Main) relay decided to act up?
spiderserie4 is online now
post #6 of 10 (permalink) Old 05-17-2019, 05:07 AM Thread Starter
I got relay from centerline I looked at picture of a correct Bosch relay but when I got it was a KAE not what I ordered.
dolmon is offline
post #7 of 10 (permalink) Old 05-17-2019, 07:31 AM Thread Starter
Charged battery all night .Started right up now what. If low voltage to the ECU was problem why would it stop when driving .Alt is putting out 13.6 volts.
dolmon is offline
post #8 of 10 (permalink) Old 05-17-2019, 07:39 AM
and KAE new on ebay are 30-40$
I agree, that photo is totally mis-leading.
I'd sooner a used Bosch (about 30 quid, used in UK, ebay) than that Kaehler.
oh well, a sign of the times I suppose.
post #9 of 10 (permalink) Old 05-17-2019, 07:57 AM
good its working, but I still wouldn't feel safe, just yet!
battery connections loose?(might account for blown fuse), ground cable bolted to trunk floor got loose?
check static battery voltage to see if your 'recharged' battery holds a full 12.6V overnight.
and then re-check cranking voltage.
post #10 of 10 (permalink) Old 05-17-2019, 08:18 AM Thread Starter
I Had just cleaned all grounds and battery connections.Thinking maybe crank sensor but they check good cold.
dolmon is offline
Similar Threads
Monterey Car Week 2017 / Concorso Italiano UndecidedRacer Car Events 6 01-02-2018 10:09 PM
Navigating Monterey car week goliardico Car Events 12 08-20-2015 04:14 PM
How hot was it today my brakes know! Alfisto Steve 164 & 168 (1991-1995) 14 08-03-2006 03:44 AM
A traumatic car week - need sympathy jamieandthemagi Alfa Romeo Topics Not Covered Elsewhere 4 05-06-2006 05:42 PM
SUPER Project...or, what I did today. CarPoor Picture Room 8 09-09-2004 10:48 AM
