Broken exhaust stud - Page 3 - Alfa Romeo Bulletin Board & Forums
 14Likes
post #31 of 39 (permalink) Old 05-28-2019, 04:42 PM
SkiBum's Avatar
A lot of the problem with aftermarket studs is they can have a different heat/expansion/contraction ratio. That can cause broken studs,loosening nuts, etc. whatever you use make sure its heat characteristics are compatible with your aluminum head and exhaust manifold. My Nissan had this issue from the factory. I replaced them with 300ZX studs and cured the problem.
SkiBum is offline
post #32 of 39 (permalink) Old 05-29-2019, 04:20 AM
Vintre's Avatar
BTW,
How did you repair the broken stud?
Vin
Vintre is offline
post #33 of 39 (permalink) Old 05-29-2019, 04:50 AM
SkiBum's Avatar
Refer to post 29..... it was M.I.A......
Vintre likes this.
SkiBum is offline
post #34 of 39 (permalink) Old 06-03-2019, 12:05 PM Thread Starter
This problem is now resolved, and I’m a very happy guy.
After failing to identify where the exhaust was rubbing on the chassis, I built some wooden stands to get the car high enough so I could have a proper look. The car fell off my jack stands a couple of weeks ago and I don’t feel good about using them for any lifts beyond 6” or so anymore. Thank heavens, there was no damage to the car. Oh, and I’m ok too.
A close look quickly revealed no contact between exhaust and chassis. Hmm, weird. Motor mounts are tight, too. Can’t be the exhaust after all, it seems.
So I refreshed my memory on the prybar-as-stethoscope trick on this forum and on YouTube, and went at it. A couple minutes later I had traced the source of the vibration to the sump, getting more and more depressed as I honed in on it.
Then I noticed, “the sump does get kind of close to that transverse chassis brace (the one painted in body color, on all cars I presume, or is it just mine?) — maybe there’s some rubbing there, somehow, even though the relative positions of sump and chassis couldn’t really have changed.
Crawling right under there, I start looking. Plenty of clearance. Hey, what’s that? Motherbrother.... the missing exhaust stud is wedged solid between sump and chassis brace, transmitting engine vibration directly to the chassis.
I wrestled it out with some needle nose pliers. It was really jammed in there.
Start ‘er up, never sounded better, winds up smooth as a turbine.
Thanks to all who gave their technical and moral support!
Incidentally, @SkiBum, your point is well taken. On replacing the missing stud I discovered another one that was very, very loose. Both are now replaced with original studs cannibalized from my old cylinder head. Lesson learned!
spiderserie4 likes this.
1976 Spider
Canadian Spider is offline
post #35 of 39 (permalink) Old 06-03-2019, 02:39 PM
PSk
Thumbs up!
'71 1750 Series 2 GTV:
PSk is offline
post #36 of 39 (permalink) Old 06-03-2019, 03:26 PM
SkiBum's Avatar
Awesome! I got a good audible laugh when you said you found the MIA stud...glad you found it and all is A-OK!
Canadian Spider likes this.
SkiBum is offline
post #37 of 39 (permalink) Old 06-03-2019, 03:51 PM
kengta's Avatar
Thanks for posting your final solution, so many don't often after much input from this BB and that PMO.
ciao
Ken
Vintre likes this.
Ken Geiger, Toronto
1965 GTA, RHD, Stradale
ex- 1965 GTA, RHD, Corsa, Trans/Am 66-72
1970 Giulia Super (CDN Spec)
1976 1600 GTj (Italian Spec)
2000 Catalina 320, Hull #765 Northern Dream
2001 BMW Z3 3.0i
kengta is online now
post #38 of 39 (permalink) Old 06-03-2019, 06:42 PM
Vintre's Avatar
Originally Posted by kengta View Post
Thanks for posting your final solution, so many don't and that PMO often after much input from this BB.
ciao
Ken
+1
Unfinished threads is a pet peeve of mine.
Thank you,
Vin
adowns likes this.
Vintre is offline
post #39 of 39 (permalink) Old 06-04-2019, 07:02 AM Thread Starter
It bugs me too when a 3-page thread includes every detail about a problem except the solution, even when a solution was clearly found years ago. The value of the forum is immeasurably higher when threads end conclusively.
PSk, Vintre, Bjorn S and 1 others like this.
1976 Spider
Similar Threads
Need help with tap and drill size for broken intake stud Boca Spider - 105 & 115 Series (1966-1994) 8 06-30-2016 03:29 PM
Exhaust manifold with a broken flange? Keyspider Spider - 105 & 115 Series (1966-1994) 3 09-21-2012 01:19 PM
Removing a broken exhaust manifold stud ZAR905A1C Milano/75 (1985-1993) 0 05-27-2012 02:15 PM
Exhaust Manifold Stud Superflow Spider - 105 & 115 Series (1966-1994) 5 05-19-2012 10:48 AM
man this is tiring..exhaust stud sort of pulled... bianchi1 Spider - 105 & 115 Series (1966-1994) 2 04-15-2009 06:08 AM
