Differential Clunk - Page 3 - Alfa Romeo Bulletin Board & Forums
 9Likes
post #31 of 41 (permalink) Old 05-13-2019, 06:05 AM Thread Starter
Vintre's Avatar
Originally Posted by Gubi View Post
Don't Mess With It
Agree
Vin
Vintre is offline
post #32 of 41 (permalink) Old 05-13-2019, 06:08 AM Thread Starter
Vintre's Avatar
Originally Posted by goats View Post
Ok any movement fore/aft in the pinion? ( I doubt there is but just finishing the Dx)
Ran out of time last night.
I will do it when I get home from work and just think about it all day
Vin
Vintre is offline
post #33 of 41 (permalink) Old 05-13-2019, 07:37 AM
Gubi's Avatar
While you're down there, grab the shafts on both sides of each u-joint and try to turn in opposite directions. You're looking for play in the u-joint. Any play and you've got an issue.
Also check for play in the splines while you're at it.
1974 GTV
1991 Spider
Former: 1987 Milano Gold
Gubi is online now
post #34 of 41 (permalink) Old 05-13-2019, 07:59 AM Thread Starter
Vintre's Avatar
I replaced the U joints and centre support in May of 2014, so under 10K miles ago, but of course I will check.
It's interesting you mention the splines. This area right?
I say interesting because I was talking to mcola over the weekend and we talked about greasing the driveshaft. I don't think I had done that last year, so I went under and greased it.
Went for a drive and while the clunk is still there, it doesnt happen as much.
What are you thinking about when it comes to the splines and clunks?
Vin
Vintre is offline
post #35 of 41 (permalink) Old 05-13-2019, 09:00 AM
Gubi's Avatar
Yeah, that section. Play anywhere can cause noise. If the splines are worn (perhaps because of lack of grease) they can clunk, so check there for play as well.
That knurled cap is (I think) supposed to only be hand tight, but I had a tiny bit of play in my splines that went away when I tightened it up a bit more. No idea if this was the right thing to do or not.
1974 GTV
1991 Spider
Gubi is online now
post #36 of 41 (permalink) Old 05-13-2019, 01:39 PM
spiderserie4's Avatar
if the splined shaft is too worn (0,2mm max play is the spec., at least for 1600/1750 it is, can't see why the 2000 would be any different) there is not much you can do, but buy a new rear prop section for 250 bucks.
the knurled nut just needs hand tight, but I do a tiny bit more with vise grips as you can't really get a good grip with your hands all covered in grease!
In fact its worth undoing it when greasing to make sure the grease is going in properly and is not all dried grease.
That sliding joint requires greasing every 4k
spiderserie4 is offline
post #37 of 41 (permalink) Old 05-13-2019, 02:48 PM Thread Starter
Vintre's Avatar
Ok,
The differential input flange is solid. No fore/aft movement.
All the u joints are tight, no movement.
No movement in the splined section. The knurled nut could be turned by hand about 1 rotation. I totally loosened the knurled nut and put in more grease, tightened the knurled nut by hand and then a quarter turn or so with pliers to get it good and tight.
I will take her out for spin and report back.
Vin
Vintre is offline
post #38 of 41 (permalink) Old 05-13-2019, 04:25 PM Thread Starter
Vintre's Avatar
Well.........what can I say?
Took her out and did my best to make the clunk but I couldn't.
The only thing I can say I did was loosen the knurled nut and put in more grease, then tightened the knurled nut as described. Tighten by hand and a quarter turn or more with pliers.
I am thrilled that the clunk is gone but just can't believe that the grease and nut was all it took.
Want to thank everyone for contributing and teaching me a few new things.
Sincerely,
Vin
radamm, spiderserie4 and Top Down like this.
Vintre is offline
post #39 of 41 (permalink) Old 05-13-2019, 04:47 PM
crackie's Avatar
FWIW this jogged my memory about the same on my 69 Spider. I had a noise of some sort (can't recall if it was "the clunk" like yours) and did the same with lube & tighten the knurled nut and solved whatever it was. So seems it is not uncommon.
Glad it was simple.
--S
Vintre likes this.
--Scott
Current: 85 GTV6, 69 Duetto, 17 Giulia, 74 GTV
Past: 65 Giulia Sprint GT, 77 Alfetta, 79 Alfetta, 87 Milano Gold, 74 GTV (Euro)
crackie is offline
post #40 of 41 (permalink) Old 05-14-2019, 01:50 AM
I'm gonna get under mine now
I do think the trick is to undo the knurled nut completely when greasing.
But sure glad for you Vin, that it was one of the cheap fixes!
.....though, if I'm honest, I was getting all ready for one of your great teardown threads with photos
post #41 of 41 (permalink) Old 05-14-2019, 06:36 AM Thread Starter
Vintre's Avatar
I'm glad it was a cheap fix as well.
If I'm honest, I was getting all ready to that teardown thread with photos as well!
I might just do one to replace the friction disks in the differential.
Thanks again,
Vin
Vintre is offline
Similar Threads
For Sale: Weissman "Magic" Locker differential Sniady Alfa Romeo Parts For Sale & Wanted 7 12-26-2018 11:23 AM
Rear Bearing Diagnosis Terry Spider - 105 & 115 Series (1966-1994) 17 06-21-2017 12:02 AM
For Sale: Alfaholics limited slip differential in Giulia 105-series rear axle | the Netherlands Giulia1600Super Alfa Romeo Parts For Sale & Wanted 4 03-17-2017 10:40 AM
Clunk noise when turning right or braking P911Tom Spider - 105 & 115 Series (1966-1994) 12 07-20-2016 12:31 AM
Differential Air Vent Question P911Tom Spider - 105 & 115 Series (1966-1994) 3 07-11-2013 10:35 AM
