Inherited a 1969 1750 Spider Veloce Euro - Alfa Romeo Bulletin Board & Forums
 29Likes
post #1 of 47 (permalink) Old 05-10-2019, 05:15 AM Thread Starter
Dr. Lo's Avatar
My first post here! My father bought the car in Rome in 1969 and shipped it back to Canada. He drove it summers only for the better part of 10 years. It has not been driven since at least 1978. It has just over 41,000 miles on it, and it’s been in a heated garage all this time (roughly 40 years!!). I decided to take it on as a restoration project.
The body is actually in pretty darn good shape. No significant rusting to be seen. The leather interior looks good as well.
The brakes are seized, so those need to be addressed before it can be rolled around.
The crank shaft also seems seized (tried turning it with by pulling on the fan to no avail). Maybe some lubrication and a bit of elbow grease will unglue it.
I have to bring it to a mechanic to have it fully inspected and know what I’m actually dealing with in terms of restoration. I’d like to do at least some of it myself, like the brakes, suspension, and rebuffing of the paint.
Dr. Lo is offline
post #2 of 47 (permalink) Old 05-10-2019, 06:05 AM
nealric's Avatar
Wow. Looks like a very cool project, and very much worth bringing back from the dead. If you'd like to move it to a more suitable work location before working on the brakes, I'd suggest buying a set of wheel dollies.
I would have been surprised if the engine DID turn over. The oil has had over 40 years to congeal into paste. It's probably not worth trying to get running without a full rebuild first. Even if you can get it to turn over, I suspect the seals will leak like sieves once there is pressure in the crank case. The good news is that parts are still readily available and these are not overly tricky motors to rebuild.
Overall, the mechanical side of restoring these cars is pretty easy. If you have a good rust-free body, you are already starting several steps ahead. You have the benefit of the fact that Alfa Romeo used essentially the same mechanical bits in the Spider from the 1960s to the mid 1990s (with a a few relatively minor changes over the years).
1986 Spider Veloce Turbo
nealric is offline
post #3 of 47 (permalink) Old 05-10-2019, 06:31 AM
BB Janitor
ghnl's Avatar
Welcome to the BB. It does look like a worthwhile project. Thanks for the 'before' photos. Keep posting - we like photos and will try to answer questions (some answers may actually prove useful...).
Susan likes this.
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
ghnl is offline
post #4 of 47 (permalink) Old 05-10-2019, 07:03 AM Thread Starter
Dr. Lo's Avatar
Thanks folks! Any idea how much a full engine rebuild could cost?
Dr. Lo is offline
post #5 of 47 (permalink) Old 05-10-2019, 07:15 AM
nealric's Avatar
It will depend on what condition the engine is in once you open it up. If everything is in good shape (Crank, pistons, liners), then the parts for a good refresh (seals, gaskets, bearings, rings, water pump, distributor) should run around $1,000. If you do a more full rebuild and replace pistons/liners, then double that. Labor will depend on whether you DIY, what machine work you have done, or who you have rebuild it. Note that if the head studs are corroded, it would likely be better to just start with a different core. 1750 cores aren't quite as plentiful as the later 2 liter cores, but still not terribly difficult to come by. A lot of people have swapped 2 liter engines into these cars, but some prefer originality and the character of the more freely revving 1750.
nealric is offline
post #6 of 47 (permalink) Old 05-10-2019, 07:33 AM
That's awesome. Welcome. I would suggest tacking the engine last, especially if you are also considering any kind of body work but getting it out of there and a good wash/clean up will tell you more. Engine last as it's undesirable to pour a bunch of moola into doing a nice engine then have it sit there in the corner for a couple of years or ten, corroding away while the other jobs get done. If you can, fix that engine, if you end up swapping in another engine, then at least save that block as you may want to make the car more correct in the future. Although Alfa's are not a "numbers matched" type of thing, there are definitely bodies and engines that are supposed to be together. Patina is not necessarily a bad thing, bunch of rust would be though. Should be a fun journey, lots of help here and even though you are in Canada, there is help around here too.
Cheers,
Carson, 4 Alfa's, 9 Cars, 4 Motorcycles
vintagemilano is offline
post #7 of 47 (permalink) Old 05-10-2019, 08:00 AM
sloboy89's Avatar
This looks really exciting. Good luck with it.
(I need to complain to my parents about not storing anything but useless junk for the last forty years.)
jthames, garwood1, Susan and 1 others like this.
Rich
'85 Spider Veloce
'17 Giulia Ti Sport
sloboy89 is offline
post #8 of 47 (permalink) Old 05-10-2019, 08:03 AM
Congrats! Looks like a fun and hopefully easy project.
I drove a 69 Spider back in the 80's and a guy approached me saying "that's my car." Confused, I asked him what he meant. He told me he had saved his money up and was all set to go to the Alfa dealership and buy a new 69 Spider, but his dad went down the day before and bought the car out from under him. His mom and dad then proceeded to drive all over the US and Canada three different times in six months, putting on 90K miles. According to the son they didn't do any maintenance during or after their trips, and once completed, the motor was shot and the car never ran again.
Hopefully you don't need it but I have a clean 69 Spider core sitting in my garage.
Chuck
6alfas is online now
post #9 of 47 (permalink) Old 05-10-2019, 08:08 AM
spiderserie4's Avatar
you even have the original alfa hardtop
that looks like a great project.
I agree with above.
Get it out of there, then a thorough wash to see what you are dealing with...
oh and then post some more photos!
Susan and triz like this.
spiderserie4 is online now
post #10 of 47 (permalink) Old 05-10-2019, 08:22 AM
glad to know there are still surprises out there waiting for a second life
Susan likes this.
Austin Alfa is offline
post #11 of 47 (permalink) Old 05-10-2019, 08:58 AM
Alleggerita's Avatar
Whereabouts in Canada are you located?
Alleggerita is online now
post #12 of 47 (permalink) Old 05-10-2019, 09:23 AM Thread Starter
Dr. Lo's Avatar
Ottawa
Dr. Lo is offline
post #13 of 47 (permalink) Old 05-10-2019, 10:51 AM
sbadaro's Avatar
Lucky 13. Appreciate all the opinion here, but before throwing the towel on the original engine, I suggest you start by draining and replacing all liquids first then proceed to rocking the old girl back and forth in 5th gear (a lot... As in over a few days) until it's free.
Chances are your head gasket and most seals and rubber parts will have been long gone, but then again there is a faint but fair chance that brakes will unseize and the engine will turn on its own power even 40 years later (mine did after 11 years of sitting).
Good luck with this beauty.
Sent from my F8332 using Tapatalk
sbadaro is online now
post #14 of 47 (permalink) Old 05-10-2019, 11:23 AM
USTA BE AN AD-MIN
ossodiseppia's Avatar
$5k - $10k. Price depends on the condition of the engine and who is doing the work.
sbadaro likes this.
ossodiseppia is offline
post #15 of 47 (permalink) Old 05-10-2019, 11:25 AM
USTA BE AN AD-MIN
I would put some sort or oil or marvel mystery oil in the cylinders before doing anything like that.
sbadaro likes this.
Similar Threads
For Sale: 1969 1750 Spider Veloce (USA) Sticker Set (EARLY) ossodiseppia Alfa Romeo Parts For Sale & Wanted 2 08-26-2019 08:18 PM
Chassis Numbers for 6C 1750 and 1500 bell904 Limited Production (1910-1949) 132 04-18-2018 05:35 PM
1750 spider veloce, euro spec. VIN & ENGINE NO jeng Spider - 105 & 115 Series (1966-1994) 2 10-11-2017 10:32 PM
1969 1750 Spider Veloce?? Anfanuts Electrical, Chassis & Lighting 2 12-14-2007 07:51 PM
1969 1750 Spider Veloce for sale Andrew Alfa Romeo Cars For Sale & Wanted 4 11-28-2006 11:03 AM
