Installing new seat upholstery - Alfa Romeo Bulletin Board & Forums
 6Likes
post #1 of 28 (permalink) Old 04-25-2019, 06:13 PM Thread Starter
SkiBum's Avatar
Hello all! I just received my new seat covers in the mail. I have new foam too, and I took the passenger side out to look things over. There are a couple of springs that are broken that I will need to replace( these are the S3 sport seats) and there are some tension wires that feed through a cloth channel in the covers that hog ring to the wire frame in the new cushion. Looks fairly straight forward but tedious. I searched and found no threads about the process..... if there is one can someone help me out? I would like to possibly get some insight from someone who has done this already.. thanks!
Shakey likes this.
SkiBum is offline
post #2 of 28 (permalink) Old 04-25-2019, 06:48 PM
lgbalfa's Avatar
Send a message via Skype™ to lgbalfa
Good luck.
I ended up paying an installer to do mine.
kbartosiak likes this.
1992 Alfa Romeo Spider Veloce, 2017 Alfa Romeo Giulia, 2018 Volkswagen Tiguan SEL Premium
lgbalfa is offline
post #3 of 28 (permalink) Old 04-25-2019, 06:59 PM
Originally Posted by lgbalfa View Post
Good luck.
I ended up paying an installed to do mine.
Me too but I used to pay $50 per cushion. Now it's $100 😫😫
Unfortunately when I try to do it myself it looks like I did it myself...
Ranz and kbartosiak like this.
gprocket is offline
post #4 of 28 (permalink) Old 04-25-2019, 08:19 PM
USTA BE AN AD-MIN
ossodiseppia's Avatar
I'm not familiar with S3 seats. So, pictures of the springs might help. If they look anything like the ones in my picture, you can make them yourself.
ossodiseppia is offline
post #5 of 28 (permalink) Old 04-26-2019, 12:39 AM
spiderserie4's Avatar
good thread here on s4 seats (which should be same as your S3 sport seats)
https://www.alfabb.com/bb/forums/spi...t-seat-s4.html
spiderserie4 is online now
post #6 of 28 (permalink) Old 04-26-2019, 01:52 AM Thread Starter
SkiBum's Avatar
Thanks for sharing the link! I will start the process tomorrow. His insight will surely help me as I tackle this job which has me quite anxious. I may add to his thread if I find some tricks that help me along the way....
SkiBum is offline
post #7 of 28 (permalink) Old 04-26-2019, 04:16 AM
BMX
I had no skill in upholstery when I recovered my S2 seats with covers from CA but it was really rewarding and i think i did as well as some of the "pro" jobs you see: hog ring pliers, hog rings, zip ties, time and patience is what you need, most of the tension springs were rotten on mine so I replaced them with zip ties, worked a treat
Top Down likes this.
1975 Spider S2
BMX is offline
post #8 of 28 (permalink) Old 04-26-2019, 05:24 AM
ntvnyer's Avatar
Seats
Ditto to what BMX said. I did mine with my then 12 Y/O son over a weekend and the came out 100% perfect. No wrinkles or defects at all, and it was my first try at seat upholstery. I used various sized O-rings and just one or two zip ties. Just take your time and have everything that you need on hand before you start. Good foam is very important, if your foam is not good replace it. I got my kit a World and it was a perfect fit. My only disappointment is the the headrests are stitched and not heat embossed as original. the attached pic show part of the seats, the rest look just as good after about 7 years
Nick S.
1974 Spider
ntvnyer is offline
post #9 of 28 (permalink) Old 04-26-2019, 09:38 AM Thread Starter
SkiBum's Avatar
Welp, played with it a while this morning, all the wire struts were rusted and brittle so useless. Started to use some insulation struts I had left over. Became obvious soon that since the sport seat is basically 4 different "lobes" that attaining a flawless job was highly unlikely ( yes, I am a bit of a perfectionist). So I farmed it out. They are at an upholstery shop down the road, should have them back in a few hours. I'm sure I can handle the seat backs and headrests on my own....thank you everyone for your input and experience!
SkiBum is offline
post #10 of 28 (permalink) Old 04-26-2019, 05:00 PM
lgbalfa's Avatar
Why won't you let the upholstery shop do the seat backs and headrests as well?
lgbalfa is offline
post #11 of 28 (permalink) Old 04-26-2019, 05:01 PM Thread Starter
SkiBum's Avatar
Because the seat backs and headrests were simple.
SkiBum is offline
post #12 of 28 (permalink) Old 04-28-2019, 12:33 AM
John533i's Avatar
I will need to do my passenger seat soon. I found a local shop and had him cut a new door card, then glue my existing 86Veloce vinyl on it. It smell like his ciggies and toxic glue for months. Glad it 'outgassed' over the winter. I'll find someone else to do my seat for sure..
86 spider Veloce
74 TR6
John533i is offline
post #13 of 28 (permalink) Old 04-28-2019, 02:05 AM
Top Down's Avatar
If you find the wires that run through the cloth under the seat cover, for the springs etc are rusted and unusable, I sourced some wire from a model aircraft shop. Its a tedious job, but with patience you can get a very nice job, just as in the post by BMX, mine looked just like that too.
Daily drive is a Giulia 2.0 MA, wife drives a 939 Spider in the summer and a Abarth 595 in the winter. For special sunny days we have a S2 Spider Junior in the garage.
Top Down is offline
post #14 of 28 (permalink) Old 04-28-2019, 05:02 AM
pantera928's Avatar
FYI, I found usable springs at an Ace Hardware store. They all have a spring assortment and one of them is almost identical to the old rusty springs. They had to order more for me as they did not have enough.
Any and all Ace Hardware stores should have the same assortment.
pantera928 is offline
post #15 of 28 (permalink) Old 04-28-2019, 07:09 AM Thread Starter
SkiBum's Avatar
I picked some up at Ace yesterday! Just looked for some with the same tension, I can adjust length accordingly.
SkiBum is offline
Similar Threads
Installing front & rear 3-point seat belts in 1967 GTV 330america GT (1963-1977) 12 02-22-2014 11:07 PM
Installing new 67 Duetto Seat Back upholstery traga Car Restoration 13 01-08-2013 06:34 AM
Giulietta Seat Upholstery from Centerline Zodiaco Giulietta & Giulia (1954-65) 0 12-12-2011 02:16 PM
installing new rear "wrap-around" upholstery D&SW 1900, 2000 & 2600 (1950-1968) 7 07-08-2008 02:01 PM
91-94 OEM Style Veloce Leather Seat Covers possibly for sale? Tan and Black. John M Spider - 105 & 115 Series (1966-1994) 44 02-13-2008 10:20 AM
