How to remove Throttle Ball Joint - Page 2 - Alfa Romeo Bulletin Board & Forums
 3Likes
post #16 of 21 (permalink) Old 05-27-2019, 06:54 PM
kengta's Avatar
Originally Posted by bhart View Post
Well, that's now sorted. Quite honestly, the WORST part of the job is removal and replacement of the mounting bracket! Terrible access and it's pretty much a one-handed job. Cleaning out the shaft and re-greasing it took less than 10 minutes. With some high temperature silicone brake lube it's operating smoothly. Ball ends no issue, especially since the car has only 27,000 miles on it, most of it in the cool climate of Norther Ontario.
Well that return spring is a part I've never seen. Mist look in s parts book
Regards
Ken
Ken Geiger, Toronto
1965 GTA, RHD, Stradale
ex- 1965 GTA, RHD, Corsa, Trans/Am 66-72
1970 Giulia Super (CDN Spec)
1976 1600 GTj (Italian Spec)
2000 Catalina 320, Hull #765 Northern Dream
2001 BMW Z3 3.0i
kengta is online now
post #17 of 21 (permalink) Old 05-27-2019, 10:17 PM
Cosimo's Avatar
The photo of your spider in the garage reminds me of something.
Bueller? Bueller?
1985 Alfa Romeo Spider Veloce
Cosimo is offline
post #18 of 21 (permalink) Old 05-27-2019, 10:25 PM
Cosimo's Avatar
I have an '85 Spider and I replaced the plastic with the metal ones from Centerline as my old one's broke when I was trying to remove them. The new ones fit very snug and are easy to remove if you forgot how to route the linkage correctly (that'd be me) and have to redo the connection a few times.
Cosimo is offline
post #19 of 21 (permalink) Old 05-28-2019, 03:24 AM
spiderserie4's Avatar
Originally Posted by kengta View Post
Well that return spring is a part I've never seen...
maybe because its a right pita to get at....
(but it is there alright)
spiderserie4 is offline
post #20 of 21 (permalink) Old 05-28-2019, 03:59 AM
Jim G's Avatar
Regards
Ken
There on all the Bosch car bellcranks. I never seen one on the carb ones.
Jim G is offline
post #21 of 21 (permalink) Old 05-28-2019, 04:01 AM Thread Starter
bhart's Avatar
The plastic joints are still fine, owing to the limited miles on the car. They do require a firm squeeze on the channel lock pliers to seat. I did spend a fair bit of time looking over the assembly in my hand, confirming the correct orientation before I installed it - kinda like one of those 'mind challenge' puzzles...
GT Junior 1300 Series 2, 1984 Spyder Veloce \(just visiting my place)
1973 1800ES, 1980 Mini, 1987 M6
bhart is offline
Similar Threads
Ball joint retaining screws Raimondo Giulietta & Giulia (1954-65) 4 02-21-2017 02:42 PM
Removal of the upper cup for the lower wishbone ball joint Lycosa Giulietta & Giulia (1954-65) 17 07-23-2016 03:58 PM
StucK Transmission Removal RandallM Spider - 105 & 115 Series (1966-1994) 67 11-20-2014 12:29 PM
castleated nut on ball joint just spins slowcpa Suspension, Steering, Brakes, Wheels & Tires 2 05-24-2012 05:32 PM
ball joint question wctouring#7 Suspension, Steering, Brakes, Wheels & Tires 2 07-03-2006 05:02 PM
